Old 12-21-2010, 01:01 AM   #1
flashdad
Converting manual to electric fuel pump
Hey folks, I'm wanting to convert from manual to electric. Got a '67 Chevy swb with a '71 corvette engine in it (350). I'm planning on putting an Edelbrock Performer manny with a 600 cfm carb on it. I need to know what a good electric pump is that is reasonably priced. AZ recommends a Spectra. Will I need a regulator? Tips, hints, or recommendations are gratefully welcomed. Pros and cons as well!
Thanks as always for your responses.
Flashdad
'67 Chevy C10
'68 GMC PU
'98 Turd F150 4x4 (I think it may be a chevy under the logo it's such a good truck)
'10 Mustang
"Life's tough - it's even tougher if you're stupid." John Wayne
flashdad is offline   Reply With Quote
Old 12-21-2010, 01:31 AM   #2
atgilford
Re: Converting manual to electric fuel pump
im not sure what a spectra is , however i went with a holley and at that time every one i talked to suggested a regulator, i got the holley brand new with regulator on cl for fifty bucks howver oreilly or your local parts store should carry it for about 120 or so.. good luck if u have any questions let me know
atgilford is offline   Reply With Quote
Old 12-21-2010, 02:48 AM   #3
darthwall
yes when running a elecric pump its basicly required im running a holley blue at 110gph and pressure set at 6lbs lots of gas and real noisy but on the plus side you can tell when the pump goes lol
darthwall is offline   Reply With Quote
Old 12-21-2010, 03:01 AM   #4
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
may i ask, why electric? im running electric due to the fact that my block has no provision for a manual pump. its been a bit of a hassle to set up......correctly that is....
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
Old 12-21-2010, 05:28 AM   #5
cdowns
cdowns's Avatar
getting rid of about the most reliable dependable unit of an engine for a headache waitin to happen makes little to no sence
Old 12-21-2010, 06:26 AM   #6
screamin_c10
I dun gradjiated collij!!!
screamin_c10's Avatar
^ x2 ^
screamin_c10 is offline   Reply With Quote
Old 12-21-2010, 08:45 AM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
i have to agree. if you are running a carb, and your engine has the provisions for a mechanical pump, then you are WAY better off with the mechanical unit.
Old 12-21-2010, 02:51 PM   #8
BP68
BP68's Avatar
I was going to go mech. on my 68, but the 89 Suburban I got the motor from did not have the provision. I got a inline Jegs pump mounted in the rear frame rail using a Jegs regulator up front with braided line going from regulator to filter on a nice hard line, and into carb. Works great so far. I had it running without a regulator, and even though it is a low pressure pump for carb application, it still had too much pressure.
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 12-21-2010, 03:00 PM   #9
vasquezmrysvll
"the other guy"
i did an in-tank unit in my rear mount tank with a return style regulator, that thing is VERY quiet. a little work but well worth it. really wish i could just run a mech. pump.
Old 12-21-2010, 08:56 PM   #10
cparman
sharp as a marble
I agree with Cdowns, and Longhorn man. Why would you want to reinvent the wheel. I have a 330hp crate motor in my Blazer, with a new stock mechanical fuel pump. Running wire in an old car/truck is time consuming, and takes a toll on the existing wiring. I am a big fan if the KISS method to our trucks!
cparman is offline   Reply With Quote
Old 01-14-2011, 11:19 AM   #11
flashdad
hmm. As for the wiring, I will be running all new wire for the truck. But it does sound llike a pain with the regulator and pressures. Maybe I will stick with my manual. Just wondering if there's a performance difference when changing to a more performance minded top end?
'67 Chevy C10
'68 GMC PU
'10 Mustang
Old 01-14-2011, 11:22 AM   #12
dznucks
dznucks's Avatar
When running an edelbrock carb with a mechanical pump, you still need a regulator to knock down the pressure to about 4 psi.
dznucks is offline   Reply With Quote
Old 01-14-2011, 11:29 AM   #13
flashdad
Does that go on the line before or after the pump?
'67 Chevy C10
'68 GMC PU
'10 Mustang
Old 01-14-2011, 01:01 PM   #14
cdowns
cdowns's Avatar
regulator would be as close to carb as possible
Old 01-14-2011, 01:10 PM   #15
VDOG
Grand PooBaa Member
VDOG's Avatar
When I installed my 91 LT1, it also had no provision for a mech fuel pump so I had to go with an electric pump. I went with a Carter Electric Fuel Pump. It was cheaper than the Holley and is rated up to 450HP.
No regulator needed with this pump. I cant think of which one but one of the Holleys do not need a regulator either. Its not that loud, and with the truck on, you cant hear it.
VDOG is offline   Reply With Quote
Old 01-14-2011, 09:06 PM   #16
406 Q-ship
406 Q-ship's Avatar
I would stick with the mechanical pump. There is no real performance advantage until you hit HP numbers in the 500 area, my Monte Carlo with a 406 that puts out 420 HP / 470 TQ runs like a scalded ape with a replacement mechanical pump (spect for a 1970 LT-1 Z28). Carter has a great mechanical pump based on the rebuildable GM pump from the 1960's that I have on my Chevelle. I would not run the Holley electric pumps unless you love the sound of them (it gets very tedious on a street vehicle).
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 01-14-2011, 09:18 PM   #17
Longhorn Man
there's a way around this... I forgot the p/n many years ago, but I have the off road needle and seat kit in my edelbrock carbs, you can run higher fuel pressure without overpowering the needle.
It seems boarderline retarded to me that Edelbrock doesn't just build there carbs with this kit in it already
