Old 12-21-2010, 09:10 PM   #1
bw4sale
bw4sale's Avatar
Same old question - Which 5 speed?
I've been exploring 5 speed options and read several threads about it, but am still undecided what I need to do.
So, today browsing CL I ran across these two trans.
1) An ax15 out of a '97 Jeep Wrangler. Newly rebuilt and never installed.$500 I know it requires an almost $300 adapter on the front side. What about using this trans in a 2wd set up?
2) An NV3500 out of an '89 GMC. 150,000 miles with new clutch kit and slave cylinder. $450
This would be going in a 2wd '68 SWB with a mild 350. Thoughts? Either one sound like a deal?
Thanks.
BRENT
-'68 Stepside Project
-'98 Z71 Daily Driver
-Enough extra parts to build another truck and a half
bw4sale is offline   Reply With Quote
Old 12-22-2010, 01:58 AM   #2
1969C10shortbed
Re: Same old question - Which 5 speed?
I thought the Camaro T5 with the S10 tailhousing was the way to go?
1969C10shortbed is offline   Reply With Quote
Old 12-22-2010, 12:14 PM   #3
bw4sale
bw4sale's Avatar
I've heard good and bad about the T5. The ax15 is supposed to be a stronger transmission. I'm also looking for something with a close to stock shifter placement.
BRENT
Old 12-22-2010, 12:41 PM   #4
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
My bud has a camaro 5spd (asume t5) and he thrashes on it, he says its still in good shape?
The NV is a 'truck trans' never read anything about the jeep trans..good luck buddy
John
1999 Toyota Tacoma 4x4
Old 12-22-2010, 12:52 PM   #5
63chevyll
gets board easy.......
63chevyll's Avatar
I wouldn't use the jeep trans unless you had the adapter. It's pretty much the same trans as Toyotas with v6's
63chevyll is offline   Reply With Quote
Old 12-22-2010, 03:57 PM   #6
dan76
http://www.novak-adapt.com/knowledge...on_gateway.htm
www.nv4500.com
Take a look at these sites. The nv4500 is probably overkill for your usage but the NV 3550 should suffice.
dan76 is offline   Reply With Quote
Old 12-23-2010, 10:13 AM   #7
bw4sale
bw4sale's Avatar
Thanks for the info.
Anyone else have any thoughts?
BRENT
Old 12-23-2010, 12:56 PM   #8
Mayo
Cool Truck
Mayo's Avatar
I have got a T5 from an 83 Camaro in my truck that seems to do just fine
1968 Chevrolet C20 Longhorn "Cool Truck"
1937 Chevrolet Pickup - Project
Looking for a patina'd 68 50th Anniversary longbed
Mayo is offline   Reply With Quote
Old 12-24-2010, 12:28 PM   #9
JJorgensen52
Simple? What's simple?
JJorgensen52's Avatar
There are three different types of T-5s running around and another, no T5 S10 5 speed (it's a muncie derivative of some kind).
Anyway, the rundown:
S10 T-5s all have the shifter forward and have truck gears. Pretty tall first. These are non-world class and are WEAK.
Camaro T-5s fall into two groups. All have car oriented ratios (had one in an S10, was a lot of fun to drive)
Pre-'89, non-world class (weak).
'90-'92, world class. These are the good ones. Only a select few have a mechanical speedo drive.
Camaro shifter is pretty far back, might be able to snake it around a bench but it would be snug.
Also, the Camaro T-5 has the tranny mount at an angle, it's like 22* or something like that. I made a custom mount for my S-10 to stand it up straight.
CURRENT
'50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build
'63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos
'66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos
'69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!)
'72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh
'99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily)
'99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs)
SOLD
'71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder)
JJorgensen52 is offline   Reply With Quote
Old 12-24-2010, 12:49 PM   #10
1969C10shortbed
From what I read on the write-up, you can use the World Class T5, with the S10 T5 tailhousing and a modified speedo gear placement. That way you get the World Class T5 strength, the better gearing, and a placement of the shifter that's very close to stock.
Old 12-24-2010, 02:07 PM   #11
Demonspeed13
Demonspeed13's Avatar
The newest issues of Custom Classic Trucks has an article where they took a Camaro T5 and put the tail shaft off of the S10 T5 , this moves the shifter about 10 inches forward . That is what I'm planning on doing to mine . I had read somewhere that the Camaro T5 with S10 tail shaft puts the shifter about the same location as the stock 3 speed .
Demonspeed13
Demonspeed13 is offline   Reply With Quote
Old 12-24-2010, 02:38 PM   #12
mvfd70
mvfd70's Avatar
Except the stock location of a 3 speed was on the steering column.
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 12-24-2010, 03:52 PM   #13
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
Thanks.
What engine are you running?
You can get a 350 Camaro WC T5. I have a friend locally (he isn't on the board) who put an S10 T5 in his truck, but he is running a 250. The T5's are great little transmissions, and can cost way less than $500. Plus there are so many options that you can do to the T5 as far as the gears you want to put in it. I would recommend doing some more research on the different trans's you want to use and figure out which would be best for you and your application.
I'm going to be running an S10 T5 behind my 307 in my '51.
Forgot to mention that there is a T5 which was used for racing. I think it was put into fox body mousetangs. Those T5's have the same guts as any other T5. You could take put the racing guts and put the in any other T5 you want. the possibilities are endless.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 12-24-2010, 05:23 PM   #14
1969C10shortbed
That's what I said..
So true
