Project 7dos
Subwoofer Enclosure<<<
I have built my own box for my 2 10" subs. It has a connecting port between the 2 subs.. Do i need to cut holes in the sides, so that the sound can escape or is better to leave it sealed.?
Thanks for the input Jason
7DOS - 1972 C-10 350/350 Porterbuilt/Accuair 20x8.5/20x10 Ride Low or Die PSSST - Yes it's bagged. 7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290 |
Depends on the type of sub's you bought. If they are designed for ported boxes then you need to calculate the correct port diameter. If they are sealed type then they need to be completely sealed, individually.
Project 7dos
thanks piston
How can i tell if they are ported type or sealed type?? They are 10" Xplod's
There should be a port sheet with each sub. It will list the idea cubic feet size of the enclosure.
I'm not 100% sure but I believe most sony subs were ported. Check the box they came in or search the model number at sony's website. |
Project 7dos
Thanks A bunch Piston!
I just found the box type sheet duh. It says sealed so I guess i will keep it sealed... Thanks again Jason
if you use a little sealant/cualk around the corners of the wood, it will seal it better than without and sound a lot better.
So Many Ideas, So Little Money
yeah, seal all wood seams and works best if you use a sticky backed foam around teh outside of the sub to seal the edge better too
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu ![]() Marshalltown, Iowa |
Has anybody got any pics of their box and where they put it. I have been thinking of how to do one for mine since i got the tank out of the cab and all. Thanks
1968 swb IM-Bufechevy56 If its to loud then your to old |
im sure you know to use mdf board for your inclosure right
box
ive built em for friends all the time and ive always used 5/8 particle board and seall all seems with liquid nail ive always built sealed boxes not ported and have had good luck im gonna build one for my truck when i get it on the road....hope this info helps
Dreaminator
Great advice. I built my first box out of plywood and it delam'd in less than a year. I also did not seal the edges. This members on this board are really helpful.
The Dreaminator Daily Driver 1971 Cheyenne 10 Lwb Tilt/Tac 402 .030 TH400. |
yeah, I thought of reminding about using MDF after I already posted. when I get a cab I am plannin on making a box for two 12s where the tank goes that fits rather tight and run some 94 olds Cutlass supreme coupe seats retro fit a console, possible the cutlass console or maybe a camaro console or build one too.. biggest thing is find the magic number for your cubicfeet inside the enclosure and get the bastard sealed good
#13 |
im going to do the same with my 72 when I get to the body I have two JL 10's in my jeep that im going to build a box and put beind the seat I like the idea of the cutlass seats.
#14 |
Dreaminator
Interesting. I removed the tank and bought an amp/8inch combo mounted on custom brackets and put pioneer 6x9 3 ways into the corners. I have 1988? Cutlass supreme buckets and they fit nice. Havent figured out how to mount the driver seat electric mechs yet. Presently have a simple big van console sold by Wolf industries.
#15 |
I got a 93 cutlass supreme and I got a truckdeck off a cutlass in th bone yard with a complete interior, so I talked to junk man into $150 and etake whatever outta the inside I want
