Old 12-21-2010, 09:45 PM   #1
unreconstructed1
nec absolutum
unreconstructed1's Avatar
Tire/Wheel/lift question.
a couple of quick questions:
I've got a 97 K2500, and I would like to put a set of 315/75 R16s on it. those wheels come out to 35's (34.6 to be precise) with a section width of 12.4 inches. would I use 12 inch wide wheels or 12.5s?
second question: what size lift would I need to put under my truck to accommodate those tires?
and last: would it be better to use a body lift, or a suspension lift?
"The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants."~ Thomas Jefferson
1967 GMC C1500 LWB 250/3 on the tree-
1969 Chevy C/10 SWB 350/TH350
1996 Chevy Silverado LWB 350/4L60E
1997 Chevy K2500 350/4L80E
unreconstructed1 is offline   Reply With Quote
Old 12-21-2010, 10:08 PM   #2
Redcap
Re: Tire/Wheel/lift question.
I would use a 10 inch wide wheel with those and definitely a suspension lift. Body lifts suck.
Redcap is offline   Reply With Quote
Old 12-21-2010, 10:44 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Agreed on both counts.
I checked TireRack's recommendations on a few 315/75-16s, and they showed rim width of 8" to 10".
I would get 10" wheels.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 12-21-2010, 11:21 PM   #4
unreconstructed1
nec absolutum
thanks for the quick reply guys. I wasn't really sure where to go to check the recommendations for the wheel size.
Old 12-22-2010, 01:39 AM   #5
Wildstreak
"something witty here"
Wildstreak's Avatar
Im pretty sure that tire size is equal to a 31.5's. I just bought a set of 265/75r16 and theyre said to be that height. I also understood that a 265/85R16 was 33''.
If you want 35's youll want lift for sure, at least 4'' lift. I like all spring rather than a block in the rear...
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 12-22-2010, 10:43 PM   #6
unreconstructed1
nec absolutum
the 75 isn't a measurement, it's a percentage. that's the reason that a 265/75 R16 is a 31 (the same thing I have on my trck right now) while a 315/ 75 is a 35.
it means that the wheel is 75% as tall as they are wide.
Old 12-22-2010, 11:31 PM   #7
Wildstreak
Wildstreak's Avatar
AH I see, I think lol. I thought that 315 was the width measurement and the 75 was the side wall depth???
57 chevy 4x4
68 burb 2wd:
Old 12-23-2010, 12:50 AM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
The first number (315, for instance) is the nominal section width of the tire in millimeters.
The second number is the aspect ratio; that is, the (sidewall) height-to-width ratio of the tire. If it is 75, the sidewall height is nominally 236mm (75% of 315mm).
That make sense?
- Mike -
RIP El Jay
Old 12-23-2010, 08:12 AM   #9
Is yours an 8-lug? 315/75s are 12.50/35s,6" lift is recommended for 88-98s,and 8" rims will do you best. Those trucks came with inset wheels (more offset) like front wheel drive cars. Bigger tires tend to stick out pretty far from the fenders. 4" and up lifts cost a lot on these trucks and all they do is space the suspension down off the frame...still stock suspension. I decided to go with adjusting the torsion bars up and using 285/75 Swamper SSRs and saved a couple thousand dollars. On 6-lug 1500/2500s you can change out torsion bars and get it up a good bit. I believe Rancho still makes that kit. There are also knuckle/spindle lifts made for the lighter duties.
Old 12-23-2010, 03:06 PM   #10
Altec
Getcha Pull
Altec's Avatar
I like 10" wheels for 12.5's. Easy to fit, and don't wear funny.
6" lift will clear for days. 4" will clear with trimming.
Suspension lift. A lot of stuff needs to be modified with body lifts. Plus, seeing the frame sucks... I really don't know much about brands. I helped a friend install a six inch Tuff Country lift on his '06. It wasn't a bad looking kit. But it was a block lift in the back.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 12-23-2010, 05:02 PM   #11
swamp rat
swamp rat's Avatar
Just for reference don't know if it will help ya. My wheels are 16.5X9.75 Tires are 33X12.5X16.5. It does not look like the sidewalls are not to far inward at the rim
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-23-2010, 05:53 PM   #12
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Same size I have.... those are the correct rims for that size tire.
- Mike -
RIP El Jay
Old 12-23-2010, 07:13 PM   #13
Altec
Getcha Pull
Altec's Avatar
Proper wheel width for a 12.5 tires is 8"-10". Same for 315/75's.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Old 12-23-2010, 08:37 PM   #14
MTCK
MTCK's Avatar
As stated above, 6" lift is ideal, 8-10" rim and more backspacing than most older trucks have. If you aren't going to wheel much I think you could get by with a 4". I ran 285's on my 98 with no lift and a slight bit of rubbing at full crank. No body lift, they are a PITA. If you want to trim without the hack job look, I like bushwacker cut out flares personally.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 12-23-2010, 11:40 PM   #15
unreconstructed1
nec absolutum
Well, I guess I'll be saving up the 1500 dollars for a suspension lift...
Old 12-24-2010, 06:40 AM   #16
Redcap
Or sell the truck and get something a little older with a straight axle, then use whatever money you have left over for improvements.
Old 12-24-2010, 01:38 PM   #17
swamp rat
swamp rat's Avatar
On sale now..
http://www.suspensionconnection.com/...on/166114.html
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 12-24-2010, 02:40 PM   #18
95 S_Trucker
95 S_Trucker's Avatar
that kit is for a 67-72, a 97 has ifs
95 S_Trucker is offline   Reply With Quote
Old 12-24-2010, 02:48 PM   #19
MTCK
MTCK's Avatar
Yeah but if he gets a 67-72, problem(s) solved!
-Marcus
Project Plow Truck
Old 12-24-2010, 06:03 PM   #20
unreconstructed1
nec absolutum
well, I've got a 67 and a 69, but they're both 2WD. and selling the 97 is out of the question because I love that truck.
Old 12-24-2010, 10:33 PM   #21
I like 10" rims w/12.50 tires except with IFS GMs because they stick out a mile in the front.
Old 12-24-2010, 11:10 PM   #22
swamp rat
swamp rat's Avatar
Woops sorry guys, sometimes that happens when ya read a thread thru the course of a couple days.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
