Old 12-22-2010, 12:17 AM   #1
saskgreen
saskgreen's Avatar
Diesel swap
Just wondering if anyone out there has every swapped in a diesel motor into one of these trucks? Me and my dad were just throwing around ideas after seeing a 76 gmc with a 453 detroit, just thought that a 6V92 in a 70 C/10 would be pretty bad ass. Any thoughts or pictures would be awesome.
saskgreen is offline   Reply With Quote
Old 12-22-2010, 12:32 AM   #2
DEISS
DEISS's Avatar
Re: Diesel swap
This guy seems to know what he`s talking about. http://www.67-72chevytrucks.com/vboa...light=longhorn
DEISS is offline   Reply With Quote
Old 12-22-2010, 04:55 PM   #3
keenan
keenan's Avatar
Re: Diesel swap
I highly doubt that engine would fit even even with alot of modifications i just did a tune up on one and there pretty hefty
keenan is offline   Reply With Quote
Old 12-22-2010, 11:31 PM   #4
saskgreen
saskgreen's Avatar
Re: Diesel swap
Not to say it wouldn't take alot of work, but it would sure turn some heads if you could ever make it work. That screamin' jimmy has a sound all too its own. Just wasn't sure if it had been done. Here is the link to the other one
Old 12-23-2010, 05:26 AM   #5
skorpioskorpio
Re: Diesel swap
You do know a 6V92 weighs a ton, I mean actually weighs a ton.... oh and is 4 feet tall.
skorpioskorpio is offline   Reply With Quote
Old 12-23-2010, 02:44 PM   #6
brad_man_72
the boat guy
brad_man_72's Avatar
Re: Diesel swap
hey dude your small block sounds like it has a few rods knocking.
brad_man_72 is offline   Reply With Quote
Old 12-26-2010, 02:00 PM   #7
saskgreen
saskgreen's Avatar
Re: Diesel swap
After doing some research, the biggest motor you can put in there is a 6v53, and it can fit, but its pretty tight. It is do-able, but would take a couple of weekends to get it put in, oh and probably a allison automatic to bolt up behind. There is a few video's on youtube if you guys are wanting to check them out.
Old 12-27-2010, 03:42 AM   #8
Hoffa
Hoffa's Avatar
Re: Diesel swap
I know you were talking about a Detroit, but I have seen a Cummins 6 cylinder in a 68 chevy 4x4 3/4 ton. To get enough depth in the engine bay, they put together a one piece front end so they could eliminate the core support and bump the radiator/intercooler out some. Looked pretty fun.
I have heard of folks putting the 4 cylinder Cummins version in. This would fit a lot better.
Nothing like the torque of a diesel.....
68 Chev SWB 2WD w/'95 LT1, 6spd, 4:56, 17" whls - family owned since 1973.
70 GMC LWB 4WD w/RAMJET 350, 4spd, 4inch lift, 33" tires, Warn Winch
72 Chev Blazer CST, 350, TH350, 4WD, factory A/C, tilt, radio delete, 77K miles, orig. paint/interior
Hoffa is offline   Reply With Quote
