Old 03-08-2003, 11:35 AM   #1
Reumster
L.E.D. Freak
Reumster's Avatar
Lowered Blazers? Gas tank skid plate?
Now that I've baged the rear of my blazer I've noticed that the Gas tank is the lowest part of the chassis when aired out. I'd like to protect the gas tank some how. Allthough when I get my hidden hitch a easy mounting method may prosent itself for a skid plate.
Specializing in Custom L.E.D. inserts.
http://www.ccled.com/
Contact me @ blazer2wd1972@hotmail.com
(406)675-8082
or Joel @ jmcwaters@eps-corp.net
1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL
Reumster is offline   Reply With Quote
Old 03-08-2003, 12:21 PM   #2
Mudder
Mudder's Avatar
I have the original Blazer skid plate on my Blazer tank. Actually helps support the tank and I have a reciever hitch. I can't get to my reciever hitch bolts without taking the tank off.
Mudder is offline   Reply With Quote
Old 03-08-2003, 12:39 PM   #3
1971short4X4
1971short4X4's Avatar
I also have a blazer tank in my 1971 4x4 and am using the blazer metal skid plate.
Tom
1971short4X4 is offline   Reply With Quote
Old 03-08-2003, 12:45 PM   #4
Reumster
L.E.D. Freak
Reumster's Avatar
Crap I remember now, I had one once. It just clicked. Man do they make these repro?
Do you have the bolt on hidden hitch?
(406)675-8082
Old 03-09-2003, 03:08 AM   #5
Dan72cst
Dan72cst's Avatar
Do any of you guys have a picture of your hitch (the part that attaches to the frame)? I have a blazer with the skid plate and want to put a receiver hitch. Any sugestions on where/how to buy one. How does it attach??? on the frame or is the skid plate between the frame and the hitch?
Marysville, WA (Dan72cst@hotmail.com)
72 4wd Blazer CST 350/350
72 4wd Chevy LWB 350/350
68 2wd Chevy LWB 327/400
Dan72cst is offline   Reply With Quote
Old 03-09-2003, 03:45 AM   #6
Mudder
Mudder's Avatar
The skid plate attaches to the cross members, like the straps. the hitch bolts to the bottom of the frame. Thats how mine is.
Old 03-09-2003, 10:03 AM   #7
jay6891
Car Knocker
jay6891's Avatar
On my truck. you have to remove the tank to bolt on the hidden hitch. I have one from ECP and a poly tank from WES. I would like some pic of this skid plate. Any repo's out there?
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 03-09-2003, 04:13 PM   #8
Reumster
L.E.D. Freak
Reumster's Avatar
I bought my hidden hitch from Dave at Early Classic. I haven't installed it yet, and fear I'll have to get my X-haust rerouted to work. Oh well it need to go threw my crossmember anyway.
(406)675-8082
Old 03-09-2003, 08:14 PM   #9
lpaine
lpaine's Avatar
Seeing this post on skid plates reminded me about a 72' Jimmy I used to own.I noticed the gas tank was leaking on it so I had to remove a section of the trailer hitch that ran down below the center of the skid plate (hacksaw job, brutal!) so I could get the skid plate off. When I took the skiplate off, it was obvious why the tank was leaking... the previous owner (my dad) had never cleaned out all the sand and dirt that had accumulated between the tank and skid plate, so the bottom of the tank was always wet, and proceeded to start rusting out. (pinholes) I managed to fix the tank with epoxy (love that stuff) and put it all back together. Moral of story; if you use your truck with skid plate on a lot of gravel roads like my dad did, you want to keep the dirt out between the skid plate and tank, and if you put a trailer hitch on with anything under the skid plate, just remember, you may have to drop the tank one day
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart
1998 Chevy 1/2 ton ex cab V-6 5 speed
1967 Chevy SWB - project truck; not started just yet
lpaine is offline   Reply With Quote
Old 03-11-2003, 12:37 AM   #10
Dan72cst
Dan72cst's Avatar
Not a very good picture, but this is my blazer skid plate over the tank. It has a cheesey hitch (not receiver) thats what the other bolts are. Does the receiver bolt behind the leaf spring shackles?
Old 03-12-2003, 11:14 PM   #11
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
LOW TANKS ARE A DRAG!
We don't use those Blazer/Sub tanks on anything lowered over 4" in the rear. Use a lower profile, tapered bottom tank.
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 03-12-2003, 11:22 PM   #12
JHickson6
I Love This Stuff!
JHickson6's Avatar
Nice tank, where can I get one? What are its dimensions and capacity? and most importantly how much?
Jared
My Rides
1967 C10 In Pieces for now
1985 Ford B700 SourPuss Bus - BIG BLUE
2003 Silverado CITY WORKER YELLOW!!
JHickson6 is offline   Reply With Quote
Old 03-12-2003, 11:50 PM   #13
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
I have these custom made for the customers application: sender/guage, filler location, internal pump(if needed), etc. I won't clutter up the Message Board any more with details & prices. You can email me for specifics.
Phone: 360-956-7170
