Old 12-22-2010, 01:45 AM   #1
red70
A few questions
First off my frame was a 6 cyl and i am wanting to move the mounts to the V8 postion and when i put the stands in the front 2 holes for the V8 vs the back 2 for the 6 cyl there are no holes in the crossmember to bolt the bottom of the stands. Do I have to drill them out? Second question im restoring my oem stock 70 outer and inner grille shell and the inner shell has some cracks in it. What can i use to bond these cracks together and also what color is the inner grille on a 70 black? semi, satin, or gloss in color?
Thanks guys
Bryce
red70 is offline   Reply With Quote
Old 12-22-2010, 02:16 AM   #2
67chevy1series
67chevy1series's Avatar
Re: A few questions
well the 70 grille is painted in a special way but yes it was black and the transmission crossmember is sifferent for a auto than a stick but if you are using the same tranny then all you need to do is move the crossmember forward and if the holes arent there then that is baffling
67chevy1series is offline   Reply With Quote
