Old 12-22-2010, 02:58 AM   #1
hick
1/2 VS 3/4 Frames...
Howdy All,
I attempted to use the search feature to answer this question but no luck.
Other then suspension is there any difference between the frames on these trucks?
While surfing another forum I saw some one take two frames that were the same, and use one to box the other. He used the same size frame though.
My pipe dream truck is 68 3/4 but finding two of those frame is next to impossible, specially in my part of the world (rust monster). I figure it would be easier to use a 1/2 to box the 3/4.
Any one able to give me some insight on this? Would it be just as easy to cut my own steel to box the 3/4?
Thanks in advance,
Scott
hick is offline   Reply With Quote
Old 12-22-2010, 08:25 AM   #2
Re: 1/2 VS 3/4 Frames...
The only difference is the rear cab mounts sit lower requiring a bigger bushing. In other words,just use the 3/4t/4wd cab mounts.They are the same frames.
Old 12-22-2010, 04:49 PM   #3
hick
Thank you Kindly,
Scott
Old 12-22-2010, 05:08 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the metal is a tic thicker on a 3/4 ton.
Old 12-22-2010, 09:47 PM   #5
hick
I figured it would be, which isn't a big deal. I just want the contours of the frame to match, as it seems much easier and seams bug me for some reason.
