Old 12-22-2010, 12:16 PM   #1
bw4sale
bw4sale's Avatar
Hubcentric
Can someone explain the types of wheels to me. I'm looking at a set of the Nissan Titan steelies and trying to figure out if they will work or not. I've heard the term hubcentric thrown around. Not sure what it means. Thanks.
BRENT
-'68 Stepside Project
-'98 Z71 Daily Driver
-Enough extra parts to build another truck and a half
bw4sale is offline   Reply With Quote
Old 12-22-2010, 12:42 PM   #2
Tony@AirRideTech
Junior Member
Re: Hubcentric
Hubcentric means that the wheel is centered off of the hub... not the lug nuts. If it were centered off of the lug nuts it will typically use a conical lug nut and be called lug centric
Tony@AirRideTech is offline   Reply With Quote
Old 12-22-2010, 12:52 PM   #3
bw4sale
bw4sale's Avatar
Re: Hubcentric
So the wheels on my 68 are lugcentric then. Do you know what the Nissan wheels are? After posting this I saw another pic of a truck with some on it, but haven't been able to find out what it takes to make it work yet. I wouldn't think anyone would go through a ton of trouble for them, but who knows.
BRENT
Old 12-22-2010, 01:12 PM   #4
geezer#99
geezer#99's Avatar
Re: Hubcentric
The major concern when swapping on newer wheels with the same 6x5.5 bolt pattern is the centre hole size.
geezer#99 is online now   Reply With Quote
Old 12-22-2010, 07:40 PM   #5
cparman
sharp as a marble
Re: Hubcentric
Hub centric wheels center on the hub of your brake rotor, or the hub of your drum. Lug centric wheels ( most aftermarket wheels )center on the lug nuts. ALL OE wheels currently are hub centric. The trouble you might have is that the hubs on your truck are larger that the Nissan wheels. If this is the case the wheels will not fit. IF they are larger then the will. OE engineers say that hub centric is preferred for a smoother truer ride.
cparman is offline   Reply With Quote
Old 12-23-2010, 12:21 AM   #6
54Caddy
GM Addicted
54Caddy's Avatar
Re: Hubcentric
i work at nissan as a tech. another tech there has a set of nissan stock steelies on his 02 suburban with no problems the hubs happen to be nearly the same. If you could measure your hub on your truck i can get you the measurment of the titans and you can have an answer if they will fit your truck.
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 12-23-2010, 10:20 AM   #7
bw4sale
bw4sale's Avatar
Re: Hubcentric
Yeah, I finally talked to someone who has put these on a 67-72. The hub size is different, but you can either machine the wheels or the rotors/drums to make them fit pretty easily.
54 Caddy, that would awesome if you could get me that measurement. Then I would know for sure what kind of fit issues I would be dealing with. Thanks a lot.
BRENT
Old 12-23-2010, 11:18 AM   #8
54Caddy
GM Addicted
54Caddy's Avatar
Re: Hubcentric
will see if i can find it on assist today at work if not ill get a micrometer and mesasure it out for you
..Mac’s Garage..
IG:MacsGarage
Old 12-30-2010, 02:44 AM   #9
PTS
Junior Member
PTS's Avatar
Re: Hubcentric
What he said! If your vehicle requires hub centric you better do that or it will vibrate even with your wheels perfectly balanced. This a shop chaser nightmare with cheap wheel lines...
Great Deals for 67-72 members on Billet Specialties, Intro Wheels, and Ridetech!
Toll Free 1-855-353-7885
PTS is offline   Reply With Quote
Old 12-30-2010, 01:49 PM   #10
cajundragger
Re: Hubcentric
Dont let it scare you. My wheels are hub-centric and I run them lug-centric. No problems.
cajundragger is offline   Reply With Quote
Old 12-30-2010, 03:05 PM   #11
SCOTI
SCOTI's Avatar
Re: Hubcentric
To further this discussion, what about the ability to interchange older & newer dually wheels?
Let's say you have an older 16" GM steel dually wheel & you want to swap to some newer 17" or larger steel GM/Dodge dually wheels?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-09-2011, 02:02 AM   #12
54Caddy
GM Addicted
54Caddy's Avatar
Re: Hubcentric
been real busy at work finally got to measure one. The assist which is our program we have with the service manuals for all the nissans does not list the measurment for the hub. i measured it and it is 3 1/16"
..Mac’s Garage..
IG:MacsGarage
Old 01-09-2011, 02:59 AM   #13
cajundragger
Re: Hubcentric
I thought alll dually wheels are hubcentric?
Old 01-09-2011, 03:01 AM   #14
SCOTI
SCOTI's Avatar
Re: Hubcentric
I've been trying to confirm this.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-09-2011, 01:10 PM   #15
texastrendz
Re: Hubcentric
my 2000 dually is lug centric, it is a c series truck(old body style). now i am running adapters to go to the ten lug wheels. they are hub centric.
texastrendz is offline   Reply With Quote
Old 01-10-2011, 12:01 AM   #16
cajundragger
Re: Hubcentric
hm guess not.
all the newer stuff is cause it increases the load capacity.
