Old 12-22-2010, 01:27 PM   #1
vintage_car
Measurement from 1950 cab to bed
The center line that runs under the rear cab window to the top of the bed, what is that measurement? mine is a 1950 chevy pu and I'm doing the s-10 swap. I'm trying to get the bed positioned properly so I know what measurements to make for the bed mounts.
vintage_car is offline   Reply With Quote
Old 12-23-2010, 09:28 AM   #2
BlueJeep
BlueJeep's Avatar
Re: Measurement from 1950 cab to bed
You really need the running boards and splash aprons on to determine how high to mount the bed on the frame.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 12-23-2010, 11:58 AM   #3
vintage_car
Yup, I thought about that last night when I was staring at it. I was going to remove the silly post this morning...
Old 12-23-2010, 02:17 PM   #4
Thadious
Unless you do what I did... push the box up 2", the fenders down 2" and just make new running board to box pieces... Kinda takes the disproportionate a little out of the cab height over the box look...
Just my 2 cents...
Ted.
'51 Chevy Build - In the design stages
Aut viam inveniam aut faciam - I will either find a way or make one.
If you don't have time to do it right the first time, when will you...
My new build - https://67-72chevytrucks.com/vboard/...70#post8958970
Thadious is offline   Reply With Quote
Old 12-23-2010, 02:42 PM   #5
RootBeer 6117
RootBeer 6117's Avatar
Second that we lifted, lowered, slid, moved, cussed, then bolted the running boards on and got it lined up within 15 minutes.
RootBeer 6117 is offline   Reply With Quote
