Dave's not here, man
Help with rear end ID
I am trying to find out what year axle I have swapped my truck over to. Here are the numbers:
KAA 023W91 3896839 on P/S and GM 80 on the D/S Any help you can provide would be greatly appreciated. I called the local Chevy dealer but they couldn't help me. I've always searched on the internet quite extensively but come up with next to nothing. Thanks!
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
Grandpa in the rustmobile...
Re: Help with rear end ID
What trans/motor did the truck originally have? Somewere around here theres an FAQ or something saying that you jack 1 rear tire off the ground spin it and count rotation or driveshaft or yoke, that'll tell you (with right formula) what gear ratio you've got.
Or pull the cover and put new gear oil/gasket (Probably needs it anyway lol)
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
post up a pic of the housing cover on your rear end that will help a lot. that was the only way I was able to tell mine was an eaton HO52. good luck with your search.
1969 ![]() ![]() ΜΟΛΩΝ ΛΑΒΕ |
I have the diff drained and know the ratio, but I was just trying to figure out the year to make it easier for replacing drums and brake parts. I guess it was all pretty much standard for 73-87 but I'm the curious type. Oldblue...I lived in North Ogden for 2 1/2 years. Not too far from your neck of the woods...
No idea where north ogden is dave, sorry lol
Google images search, Dana 60, Eaton Ho52, Coorperate 10 bolt....
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
