Old 12-22-2010, 05:04 PM   #1
Mog
Mog's Avatar
Drum to disc conversion 70 Blazer
Anyone know if there is a kit for drum to disc conversion for my 70 Blazer 4wd? Just looking to do the front. If not, I don't really know enough to buy the parts piecemeal so if someone could point me in the right direction it'd be much appreciated. Thanks, Steve
Mog is offline   Reply With Quote
Old 12-22-2010, 08:19 PM   #2
JimKshortstep4x4
Re: Drum to disc conversion 70 Blazer
Welcome to the 67-72 Chevy Truck Board from West Michigan!
If you swap out a diifferential from a 71 or 72 and change out the master cylinder/lines it is a pretty easy upgrade. Blazers and trucks have the same differential. You will want to keep the same gear ratio.
There are kits available, also.
You may want to check with the Blazer Board for their suggestions.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
