12-22-2010, 09:09 PM | #1 |
Cluster connector?
How does the cluster connector on a 68 C20 with full guage cluster disconnect? I tried pulling on it and wiggling it, no luck getting it off. Need to replace instrument lightbulbs so I can stop turning on my cab light to see them at night. Thanks. Jim.
12-22-2010, 09:26 PM | #2 |
huh?
Re: Cluster connector?
You should be able to grab it from the sides and squeeze. There are tabs that you need to push in, then you can wiggle the connector out.
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
12-22-2010, 11:28 PM | #3 |
Push it back in a little that will help you free the clips on the ends that snap into the cluster. If you have pulled it out a little the clips [or whatever they are called ] could act like a wedge and hold it in even tighter. And, if you can't get it out you could always come see me to see if I could get it out for you I am only 2/12 hours away. HAHAHA Merry Christmas . Jim
12-22-2010, 11:30 PM | #4 |
Push it back in a little that will help you free the clips on the ends that snap into the cluster. If you have pulled it out a little the clips [or whatever they are called ] could act like a wedge and hold it in even tighter. And, if you can't get it out you could always come see me to see if I could get it out for you I am only 2 1/2 hours away. HAHAHA Merry Christmas . Jim
12-23-2010, 12:32 AM | #5 |
Msgt USAF Ret
I'm puzzled, how is pulling the cluster plug out going to help change the bulbs unless you're removing the cluster? In my cluster the bulbs come out with just a 1/4 turn of the sockets and then pull out the bulbs.Are all the bulbs out or do some of them work. I ask because the panel lights fuse might be blown or you may have lost power to the gray wire that feeds the lights.
Here's a cluster with all the bulbs installed and the plug out.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
12-23-2010, 11:29 AM | #6 |
VetteVet, I'm wanting to replace the cluster front with a new one also. Otherwise, I could have just replaced the bulbs in place I guess. Only half of my bulbs are out, so I believe the fuse and wiring is good. Also, this is the first time I've pulled it, so I'm curious what else I can fix behind there easier with it out. I'd like to tye wrap up some of the wiring to clean it up some. Thanks everyone for the replies. As soon as it warms up some, I'll get to it. Did get my new air intake and electric window and switch and wood door panel on over last couple days. Door panel will be upholstered when I get the seat done. Thanks again.
12-23-2010, 11:45 AM | #7 |
Cruzin
very cool i've been thinking of doing door panels like that too instead of stock one and nice motor
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
12-23-2010, 03:07 PM | #8 |
Msgt USAF Ret
Gotcha: Here is a page from the FAQS with some threads in it that might be of interest to you. Scroll down to interior related FAQS.
Nice setup you have there. http://67-72chevytrucks.com/vboard/s...d.php?t=262547
12-23-2010, 03:32 PM | #9 |
Wiggle it around while holding the tabs in a pull hard....mine was pretty hard to get out of my C20.
12-23-2010, 08:26 PM | #10 |
Thanks for all the advice. Unfortunately didn't get to it. Had to go pick up my painting supplies from my friends house. He passed away yesterday of a heart attack. Had just landed after a hanggliding flight and had a massive heart attack. Will miss him. He was a good guy. Could do body work and paint real well. His family used to have a shop that restored Lincoln Zeffirs in Northeast Arkansas. Guess I'm going to learn how to do finish body work and paint now too. Thanks again.
12-24-2010, 11:28 AM | #11 | |
Msgt USAF Ret
from a tragic accident.
