Old 12-22-2010, 11:49 PM   #1
lownslow62
lownslow62's Avatar
help with brakes
i have a 62, swapped out xmembers with an 84. i now have disk brakes, my question is, will my stock master cylinder be enough to push them. im just gonna run a manual disk set up. its the master cylinder that is 1 resevoir but two plungers, one for the brake pedal and one for the clutch. any ideas on what i should do? thanks a bunch in advance
lownslow62 is offline   Reply With Quote
Old 12-23-2010, 01:13 AM   #2
slepysal
slepysal's Avatar
Re: help with brakes
No, the stock master is a single curicuit one resivour feeds all 4 drums, the other as you know feeds the clutch
You need a dual master cylinder for DISC brakes . You can use one off of a 72 c10 non power master.
What do you plan to use for the clutch ?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 12-23-2010, 01:33 AM   #3
Captainfab
60-66 Nut
I agree with Sal.
You will need to convert to a dual reservior master that is designed to operate a disc/drum brake system. Manual masters were available from '71 thru about '76. Don't forget you'll need the proportioning valve.
Old 12-23-2010, 01:55 AM   #4
lownslow62
lownslow62's Avatar
thanks fellas, i have a proportioning valve, and im gettin a non power master from a 74 tomorrow from napa for disk/drum. for the clutch, wilwood has a master for like 49 bucks so i figure ill just use that. my next question is the rubber mounts for the bell houseing/trans, where can i get those, im not sure if the ones i have are correct cause the truck was kinda tossed together when i got my hands on it.
Old 12-23-2010, 11:26 AM   #5
Stew64
Stew64's Avatar
I'm kinda new at this but I think LMC Truck might be a good start for the mounts. When purchasing, I have been told to buy the mounts for the year of the bell housing as opposed to the year of the truck however it may not matter.
1964 Longbed
Stew64 is offline   Reply With Quote
Old 12-23-2010, 01:35 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I like to use the manual master cylinder for an early 80s era truck. It's aluminum with plastic reservoir so they never rust or get looking ugly.
Old 12-24-2010, 01:11 AM   #7
Captainfab
60-66 Nut
If you're using the original slave cylinder, you will want the Wilwood master with a 1" bore.
