Water in my door.
Hi guys,
So with all these rains we've been having in Southern, CA, my Betsy is drenched. Today I opened the door and I can hear alot of water in the door, just sloshing around in the bottom. What should I do? Drill a small hole to let it out? Let it evaporate? How do I prevent this in the future? I guess it's because I have no weather stripping or molding (what's the correct term?) around the windows?
Thanks, Emil 1972 Chevy C20 |
Licensed driver
Re: Water in my door.
There are two drains at the bottom of the door - must be plugged up. It really helps to have the door handle removal tool - see photo below (you can find them online - I think classicparts.com had them....but probably available lots of places).
In the mean time you should be able to just use a thin stick or piece of metal and poke the holes from the bottom up and the water will flow out - long term you'll want to clean your door of the debris in there. Best, TT ![]() |
Restoring it $200 at a time...
Drill 1/8" holes every 4" or so in the bottom of the door. Once the water's out, remove the interior panel and scrape the sludge out from the inside. Go back in a week or so to make sure that the holes are still open.
New felts will help both the water intrusion and the window rattle. Good luck.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society '68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327. DD '09 Pilot Weekender '65 Skylark 300-4V-4 speed Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine. Son's '04 F250 SuperCab 6.0 |
Roadtrip!
![]() Join Date: Feb 2003
I would suggest NOT drilling holes. Just clean out the 2 drains that are there and make sure they stay open. New weatherstrip will help also.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
#5 | |
Hi, Should I be able to see the holes from the bottom of the door with the door open? I just went outside with a flashlight, I was going to try to poke the holes with a coat hanger, but couldn't see/feel any holes. I looked in from the top of the door, all I see is a bunch of water in the door. Where would the holes be located?
Roadtrip!
You should see them just by looking up from the bottom. They are approx. 1/2" long
you know where the lip is and that is the peice of door that hangs lower they are right against that close to the front and close to the back hope that helps
Thanks guys, I'll try again in daylight!
#9 | |
Rottenwood Garage Member
If you cant find them, thats why your door is full of water! Avoid drilling holes...if you are going that route just cut the door bottoms out of it. LOL
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! Last edited by 72freak; 12-23-2010 at 01:29 AM. |
fat old dude
![]() Join Date: Feb 2010
autozone has the door tool. i paid $5
1972 c-10 shortbed 350/400 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157 1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216 Accepting part donations |
The front hole is smaller and near the corner.
Thanks for the help! I found the drain hole today and unclogged it.
#13 |
Here is the tip of the day
no door handle tool remover take a old tshirt rip a section off wedge it between the door handle and door have each end in each hand move it back and forth until you feel the clip snag it and presto it will take practice but it does work and all you guys will try this tell me who gets it and ohhh yea don't drill holes in your door un plug the drain holes
Randy Last edited by RandyL1966; 12-24-2010 at 05:48 PM. |
#14 | |
#15 |
For those who have not seen the drain holes. Every truck I get I take the door panels off and stuff a water hose in the door and keep the drains clear till nothing but clear water poors out. If you keep the drains clear the doors should last another 40 years.
72 Cheyenne Super 80 Silverado Blazer 2wd |
#16 |
Theres two small drain holes in the bottom of the door that needs to be cleaned out just take the door pannel off and clean out the gunk inside the door, even the new cars have these holes. New weather stripping would help but it wont completely stop it thats what the holes are for. I hope this helps.
1969 Chevy c20(Miss Hackjob) |
#17 | |
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
