Steering column? 67-68 vs 69-72
Are just the steering shaft's different or the complete column in 67~68 VS 69~72?
I know the steering wheels are different. I'm finishing up my 68 and this is one of the last parts. Happy Holidays! Chad
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread Last edited by Mt Man Chad; 12-23-2010 at 07:04 PM. |
Re: Steering column? 67-68 vs 69-72
It's basically just the shaft, the 67/68 the intermediate shaft does not come off like the 69/72. But there are also little things like the shift lever is shorter in 67/68, and the shift indicator is different in 71/72.
Member #1049
Chad,
The 67/68 columns with the long inner shaft also have a different lower bearing retainer than the 69-72. 71/72 columns have a different pointer and shift indicator housing. |
subscribed
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
Subd
James B. 1967 Chevy Fleetside Shortbed 4X2 (Black & Beautiful) 1971 Chevy Fleetside Shortbed 4X4 (White & Rough) |
71 K20 64 GMC mud truck |
Ya i was at work. Just subd to attach it to my subscriptions. I am putting in a 700r4 in my 67 C10 soon and trying to do my homework. Some guy told me I had to use a 67-68 AT column and the other years wouldn't work without major mods. I'm slowly figuring out its possible but like anything else, there is a little work involved.
It should work regardless of column year. There's a bunch of threads about 700R4 swaps here, I'm sure you'd be able to find your answer. The detents are actually in the transmissions fortunately, not on the column.
![]() Join Date: Nov 2012
If you're going rag joint to rag joint. It is a direct swap. The only change you have to make is the wire connection on the column. The older ones have a curved connector and the later ones have a flat connector. You can get an adapter on any car parts site. Costs about $15.
If I have to be on 4 wheels, It has to be a classic Chevy 1967 c10 Longbed (Hawghauler/Icy weather transport) 2003 BMW K1200GT (Rain bike) 2007 Softail Deuce (Sun bike) 2009 Ultra Classic Electra Glide (Everything else bike) |
