fuel tanks sucking
on our 1987 GM K2500 we have replaced the fuel tanks, fuel gauges with pumps and the fuel selector on the frame as well as the switch in the dash as well as the wiring.
problem now is that the fuel when sitting in our garage will siphon out of the drivers side take and over flow the right side tank. when we move it out doors this stops??? There is a lot of vacuum when the cap is opened and leaving the cap loose it still makes it way over. I do have the vacuum canister plugged off under the hood. Has any one else had this problem or heard of this and what to do to correct it. thanks
2020 GMC Acadia Denali (Maroon) 2016 Chevy 2500hd WT (Black) 2023 Puma Palomino (White/Black) 2015 Harley FLHTCUTG Trike ( Maroon) 1995 Harley FLT (2 tone Red) 1992 Chevy S-10 4x4 Blazer (Dark Red) |
Re: fuel tanks sucking
Couple of questions... Did it do this before all the changes, or is that why you did all the changes?? Could outside temp vs garage temp have something to do with it??
1995 GMC 4x4 1/2 ton 1999 Jeep Wrangler w/ 33's 68 camaro 350/350 1987 Chevy 3/4 ton 4x4 Suzuki DRZ 400s Dual Sport 1971 chevy long bed 2x4 194? Dodge 2.5 ton 1980 Chevy Cheyenne 4x4 1/2 ton I6/sm455 1989 Chevy V30 crewcab dually 454/TH400 |
| Bookmarks |
