Old 12-23-2010, 04:21 PM   #1
jsand6769
jsand6769's Avatar
what engine should I do
So I have a 72k5 4x4, It is my DD now. I am going to tear it apart, make it nice and return it back to daily driver status( this is my choice instead of getting a new truck) so Which of the 3 engine trans combos do you all like
GMPP ZZ383 with edelbrock efi and a 700r4 (the easiest install)
96 to 98 gm 350 vortech engine and trans up grade (moderate install)
or Gm LS 6.0 and trans assy (most difficult)
I will have a 25k budgett for the whole blazer.
I am getting 8 mpg right now so I am figuring at least 15 with any of the combos listed, what do you think
jsand6769 is offline   Reply With Quote
Old 12-23-2010, 05:20 PM   #2
pumpkin
pumpkin's Avatar
Re: what engine should I do
For reliability and cost, I would go with the vortec, with tbi injection, and a 700r4. Whatever you decide, make shure you go roller cam, as the addatives are missing in the new oils to keep a flat tappet cam alive.
pumpkin is offline   Reply With Quote
Old 12-23-2010, 07:40 PM   #3
mcmlxix
Collector of Projects
mcmlxix's Avatar
LS 6.0L w/ 4L80e - NP205.... most work but best results... this is my plan anyway...
You budget is subjective and depends on the condition of the body and paint and how nice you the paint....
Rich
1972 K5 Blazer CST Click HERE
Old 12-23-2010, 09:39 PM   #4
cparman
sharp as a marble
I have a 330 hp 350 crate motor in my Blazer, with a 700r4. Rear gear is ??? I love my combination! The engine makes good power, idles smooth, and is a bolt for bolt swap. I believe in the KISS method. I own an auto repair shop, and we deal late model electronics every day. My Blazer has a 600 holley, and it will sit for weeks at a time, and ALWAYS starts. Never disapointed when I drive it. here are a few pics
cparman is offline   Reply With Quote
Old 12-23-2010, 10:06 PM   #5
HI OFCR
HI OFCR's Avatar
I have a 40smb with a 4 speed/w a 205 and 3.73 gear pulling down 11mpg on 35's. I will be doing a 5.3 or 6.0 swap when I tear mine down. I have been a part of many LS swaps and you cant beat them for power/reliability.
HI OFCR is offline   Reply With Quote
Old 12-24-2010, 10:38 AM   #6
jsand6769
jsand6769's Avatar
The body work will be good, I grew up with a body man a father so I have little tolerance for bad body work in my stuff, but I can do it myself. I saw the ls in your chevelle, I have a 67 velle also, you are doing good work there,
Old 12-27-2010, 02:41 PM   #7
Burt4x4
Burt4x4's Avatar
I would stay a bit old school with modern EFI.
So Like a 454 with aftermarket EFI mated to a NV4500 for that 5th gear..or if you want Auto the TH400 has allways been good behind the 454..
BBC for Life!
Good Luck and take Pics!
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 12-31-2010, 12:06 PM   #8
4oldcars
4oldcars's Avatar
FWIW - I'm doin a 71 2wd right now - I'm goin with a ZZ4/700R4
4oldcars
Driving:
1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado
The ones I let go:
1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed
4oldcars is offline   Reply With Quote
Old 01-17-2011, 02:48 AM   #9
yellowdawg
so if you keep the np205 and go 700r4 you dont need to change the d shafts?
yellowdawg is offline   Reply With Quote
Old 01-17-2011, 02:49 AM   #10
yellowdawg
How about a 400sbc with a TPI and a 700r4. I did a tpi and its amazing in economy and torque. I wouldnt go LS, I would go efi.
