Old 12-23-2010, 05:05 PM   #1
vintage_car
what is supposed to come first? (rear end topic)
newb on the s10 swap, and really first time hitting a project of this size...
What comes first on deciding the rear end? Ride height, tires/rims, the actual rear end? I really don't want to be buying parts and trying to make things fit. I would rather have it planned out on paper and buy the right parts that fit together.
What I know is I have a bone stock 350 and 350 trans, I'm not looking to use this as real truck, this is for cruising around, bone stock 350 is fine for me, some highway driving will be done (40/60- hwy/city). I won't be pulling anything with the truck either.
After lots of reading and some pm's- the 4x4 blazer rear end needs spacers- I'm not keen on that. 2nd gen camaro has drums, I'd like all disc- but not opposed to the rear drum setup, 3rd gen camaro is weak (read this in a few post), 94-01 explorer 8.8 is a solid rear end, but hubs needs to be re-drilled for chevy 5 lug.
So my mind is mushy and I'm looking for clarity.
vintage_car is offline   Reply With Quote
Old 12-25-2010, 02:51 PM   #2
BlueJeep
BlueJeep's Avatar
Re: what is supposed to come first? (rear end topic)
I believe the explorer 8.8 is a little narrower than the 4wd s10 axles, so you're at the same width concern there. Any of the axles you mentioned will work fine, so you might just see what you can find and what fits the budget. I personally used the 4wd s10 rear axle because I had one and it bolted in. I used spacers to get my tires to fit the fenders without tubbing the bed. I'd have no issues with the 8.8 if I had one of those, and then I'd run conversion adapters/spacers to go from the 5 on 4.5" to 5 on 4.75" bolt pattern.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 12-25-2010, 04:40 PM   #3
chev3600
chev3600's Avatar
A lot depends on what wheels and tires you'll be running. Since custom wheels can be ordered in a number of different offsets and bolt patterns for sure, if that is your route, pick the rear end first. I found that the explorer rear end with lug conversion spacers fit the wheels I already had perfectly. The spacers are real solid and a bone stock 350 likely wont torture anything. 2 cents.
1949/1954 with LS swap-yeah!
http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos
chev3600 is offline   Reply With Quote
Old 12-26-2010, 07:41 PM   #4
vintage_car
what is a decent year for the s10 4x4 rear? any models to stay away from or look for? One other item is, why is the 2wd rear end not a choice one to use?
Old 12-27-2010, 11:08 AM   #5
BlueJeep
BlueJeep's Avatar
2wd is about 5" narrower than 4wd, that's why we don't run that one. Any year s10 4wd will work, but 98 and up Blazer rears are disc brakes.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
