Old 12-23-2010, 10:54 PM   #1
bad61
Help on vin and paint#
I have found sites that help with vin tag decoding but i can't find anything on bench seat color or exterior color. I also have custom trim and my tag says
trim-STD(standard).
paint-RPO721H
vin-OC144L1O7148
help please.
bad61 is offline   Reply With Quote
Old 12-23-2010, 11:04 PM   #2
kalirodding
CLASSIX Truck Club
kalirodding's Avatar
Re: Help on vin and paint#
The exterior code should be on your Tag on the driver side kick panel. Not to sure about the seat color.
kalirodding is offline   Reply With Quote
Old 12-23-2010, 11:05 PM   #3
kalirodding
CLASSIX Truck Club
Sweet truck by the way. A lot of 61's popping up.
Old 12-23-2010, 11:07 PM   #4
bad61
I found the tag I just don't know how to read it.
Old 12-23-2010, 11:10 PM   #5
protrash64
Resistance is Futile
protrash64's Avatar
Did you try the FAQ section above the threads? There is a vin thread; haven't read it though......
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 12-23-2010, 11:12 PM   #6
bad61
love these trucks
Old 12-24-2010, 09:51 AM   #7
onequickchevy
onequickchevy's Avatar
What's the story on the circle track style truck? That is one mean looking son of a gun!
Slowly but surely getting it done.
onequickchevy is offline   Reply With Quote
Old 12-24-2010, 09:56 AM   #8
protrash64
protrash64's Avatar
x2....mean-a$$ rubber under those fenders.....looks like it should be slinging some dirt and mud.
Old 12-24-2010, 10:29 AM   #9
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
paint-RPO721H.... in 1960 rpo721 was called pure white. solid color truck, not two tone.
vin-OC144L1O7148... 0= 1960, C= 2wd, 14= swb 115", 4= pickup, L= los angeles assy. plant, 107148= 7148th built that year.
Old 12-24-2010, 10:48 AM   #10
bad61
thanks missoula!
Old 12-24-2010, 11:00 AM   #11
bad61
I like your work Jons custom shop! I was raised in billings and have deep roots in montane, thanks for your help. The trim says it's standard but it's custom, could they have screwed up at the plant?
Old 12-24-2010, 06:34 PM   #12
jonzcustomshop
1961 crewcab
I was thinking the trim-std might refer to the interior, the bbw and custom cab stuff might have been a rpo that would be on the build sheet, but not the tag.
I have a 66 bbw with the trim , and the build sheet lists both of them , I will have to check the kick panel tag and see what it says.
Old 12-24-2010, 06:49 PM   #13
bad61
do you have the chrome trim that goes in the rear window rubber? i'm on the hunt for it.
Old 12-25-2010, 01:43 AM   #14
jonzcustomshop
1961 crewcab
as far as I know the very first pic you posted is correctly trimmed out.
in the aftermarket you can get a rear rubber with a chrome bead lock, but it is not factory correct.
