12-23-2010, 11:09 PM | #1 |
Resident of Here
Frame straight for bags?
If a truck's frame is bent 3/16" will it affect an air ride system? It's a straight axle 4x4. Should it be fixed first?
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
12-24-2010, 01:31 AM | #2 |
Re: Frame straight for bags?
Where is the frame bent? 3/16's isnt to bad. These frame are known for moving around a flexing. it isnt uncommon to have them out that much to start with. Maybe some pictures would help!
My build thread. Boy what did i get myself into! |
12-24-2010, 02:28 AM | #3 |
Resident of Here
Dad got it checked without me. And he doesn't remember where. But the truck dogwalks down the road. I hate following it somewhere, it looks like it just got in a crash.
12-24-2010, 04:21 AM | #4 |
if it is dog walking it could be the rearend. so i would make sure that it is correctly centered. If it is bend enough to have the truck track like that, then i would think it would be a lot more then 3/16's. get under it take a look take some measurements and get to the bottom of! then move forward with your plans.
My build thread. Boy what did i get myself into! Last edited by draggin86; 12-24-2010 at 04:22 AM. |
12-24-2010, 10:56 AM | #5 |
I wouldn't do anything until the 'dog-walk' is remedied. Going straight down the road should be the main priority after safety.
12-24-2010, 11:12 AM | #6 |
it will take more than 3/16 to make it do the ol' sideways crab walk ... as already posted, check the rear-end and make sure it isn't "canted" or mounted in some crooked fashion.
A good way to start is to measure center of front wheel to center of rear wheel on both sides and compare the numbers. Last edited by Shane; 12-24-2010 at 11:50 AM. |
12-24-2010, 11:20 AM | #7 |
Resident of Here
Ok, thanks guys. I replaced the original blown rear-end with a rebuilt 40K mile 89' rear end back in February/March. Hadn't had the truck that long, so I didn't know if it was dogwalking. I also forgot to recheck the torque on the u bolts after the original fitment.
12-24-2010, 06:46 PM | #8 |
You would be surprised how easy it is not to get that rearend right on the centering pins on the leafs!
12-25-2010, 01:36 AM | #9 |
Resident of Here
Well, it's on the pins. Dad said when he brought it to get the 4-wheel alignment checked the guy measured the rear end. I'll measure as well to make sure. Also, the front alignment has not been done since we've had the truck.
