I was Framed
BAHHAHAAA Anybody know if there is any dfferance' between a 1/2 ton frame and 3/4 or 1 ton frame.Are they the same or did they do something differant I am thinking of making another 1/2 ton truck that is sitting on a 3800 chassis would they be the same?Thanks and ya-all have a Merry Christmas
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
Re: I was Framed
from memory 3/4 is same dims as 1/2 just thicker frame metal. 1 ton may be a llittle deeper section. when I get to a computer I can post a link to place that has all the dims.
Posted via Mobile Device missed it was an AD truck, others know more
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project Last edited by OrrieG; 12-25-2010 at 12:57 AM. |
Re: I was Framed
1/2 ton tapers front to rear
3/4 ton taper stops at the back of the cab then straight back 1 ton is like the 3/4 each gets a longer in the wheelbase and the frame gets heavier. |
Re: I was Framed
also, 3/4 ton frames are a quite a bit narrower in the rear. i can pull a measurement if you would like.
so yes, longer and narrower.
1950 3600. 370cid, th400, 9", billet 80mm turbo under the bed, 4 link coilovers, hoping for a single digit! http://67-72chevytrucks.com/vboard/s...d.php?t=380212 |
Hellasick
![]() Join Date: Jul 2006
Re: I was Framed
The 1 tons also have no axle arch, at least mine doesn't.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys |
Lost amongst the CORN
Re: I was Framed
The metal is thicker and the rails are slightly taller on the 3/4 ton.
Currently working on How To Videos and custom metal 70 Chevelle gettin Sliced and Diced Anything But STOCK 70 Chevelle SS455 not a typo its a BUICK BABY 49 and 72 Chevy Trucks restored to original...close to it Drommer Stor....Norwegian for Dream Big http://s969.photobucket.com/albums/a...lle/?start=all https://www.flickr.com/photos/47922830@N03/ Pictures of my work and projects |
