Old 12-24-2010, 04:19 PM   #1
FLcustom10
Differential question
I have started cleaning the frame and sprayed everything with Simple Green and then used the pressure washer. Now I'm seeing fluid coming from the top of the Differential. Have I knocked something loose that I shouldn't have?
FLcustom10 is offline   Reply With Quote
Old 12-24-2010, 04:43 PM   #2
Alex Hayley
Re: Differential question
If I am seeing the same fluid you are seeing, it is a hole in a casting plug. Fairly common issue and easy to solve. Just plug the hold with jbweld. You might want to drain the fluid first.
Alex Hayley is offline   Reply With Quote
Old 12-24-2010, 05:05 PM   #3
LONGHAIR
That is a leak past one of the original welds that holds the tubes in the center section. It really shouldn't leak out the top though? Was this thing upside down during the cleaning process?
Lots of them are slightly damp there, usually just enough to hold dust, but the seepage is minimal. Be sure that the vent hose is not clogged, that will aggrivate this condition.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 12-24-2010, 05:20 PM   #4
FLcustom10
It wasn't upside down while cleaning, but I wasn't being careful with the pressure washer in that area either. The JBWeld sounds like a good idea to me. I'm just getting started and am in well over my head so I'll be back with more questions. Thanks guys.
Old 12-24-2010, 05:49 PM   #5
HavinSomeFun
Still Just Havin Some Fun!
HavinSomeFun's Avatar
Smile Re: Differential question
I'm In Tallahassee also. Have questions or need a little direction PM me and I'll help where I can or come over and really lend a hand if needed. Just remember, its only nuts and bolts when you think about it.
a green one with some stuff done to it....
HavinSomeFun is offline   Reply With Quote
Old 12-24-2010, 06:16 PM   #6
FLcustom10
That's great! Thanks - I'll PM you.
Old 12-24-2010, 06:22 PM   #7
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
^awesome!
John
1999 Toyota Tacoma 4x4
