transmission floor clearance
hi all, anyone know if a tremec 5 speed will fit under a small hump 66.thanks
Re: transmission floor clearance
I had the same question about a 700R4 and I got replies that it would fit. My other thoughts were going with the Tremec. I would think it would, but hopefully someone chimes in with a absolute yes. Merry Christmas!
1963 Chevy stepside 327 1965 Chevy swb 383 1996 Mystic Mustang Cobra 2009 Pontiac G8 GXP 415hp/415tq 6speed |
Pic is of a TKO 600 in a low hump 61.It didn't clear but I was using the front "horseshoe" mount along with the mounts on the bell housing.If you have the side motor mounts you could probably drop the tail end of the trannie a little to make it clear the hump.I am no expert at this so I don't know if dropping the rear of the tranny would cause any alignment issues with the drive train but I would ASSUME you would be all right.The high hump cover and the corresponding firewall piece would do the trick if you don't want to mess with too much fabrication.Hope this helps!
