HELP!!! See pic; How do I remove this bolt?
I'm installing a KP Components Watts Link and I have a bolt on the upper passenger side on the rear end (see pic) that I need to remove due to interference. I think it might be called the panhard bar bolt(?) possible. Is it threaded thru or does it need beat out? I don't want to screw up threads so hopefully someone out there can let me know. (The pic shown is not my truck; I used a pic off 67 cheby's build cause this is basically what my truck is in the rear before today is over!!!
Re: HELP!!! See pic; How do I remove this bolt?
Take off the nut and give it a wack!!It is a tapered fit stud(not threaded).Should pop right out!
69 Lwb C-10 402/700R4 70 Lwb C-10 250/3pd Wisc. |
That bolt is friction fit (pressed in) to the hole. I put a couple nuts on the end and "gently" tapped mine out with a big hammer.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
Thanks alot for the quick response. I'll have pics when my install is complete!
if not going to b used then why not just cut and grind the mount and clean smoothe with a cutoff wheel
it pounded right out. Thanks guys
