03-08-2003, 09:01 PM | #1 |
rear end ratio ?
Is there a fairly accurate equation to figure rear end ratio if you know engine RPM and tire diameter?
FocuzTech Performance Evergreen Protective Coatings Gatorhyde...the best kept secret in spray in bed lining & protection |
03-08-2003, 09:10 PM | #2 |
gear ratio = (rpm x tire diameter) / (mph x 336)
2004 Silverado - Beater 1969 GMC - In progress http://67-72chevytrucks.com/vboard/s...d.php?t=441683 2011 Aveo - Work commuter 2013 Crestliner Fish Hawk 1650 - The reason no work gets done on the project truck. |
03-08-2003, 09:11 PM | #3 |
With the 350/350 combo you could have a 3.07 or a 3.73.
gear ratio = RPM XTire diameter divided by MPH X 336
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
03-08-2003, 09:13 PM | #4 |
Hehe, beat you by probably 10 seconds.
03-08-2003, 09:33 PM | #5 |
member #16
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
03-09-2003, 12:48 AM | #6 |
its all about the +6 inches
Or you could pop the cover off and chainge the 10 - 30 yr old oil and cout the teeth on the gears.
03-09-2003, 06:56 AM | #7 |
ratio
jack up the rearend & count the driveshaft revolutions it takes for the wheel on one side to make one revolution. On a non-posi, just jack up one wheel......
03-09-2003, 09:39 AM | #8 |
"Ochre Ogre"
...but count the drive shaft revolutions during 2 full revolutions of 1 tire to get the approximate gear ratio.
and I like to use the calculators at Randy's ring and pinion. www.ring-pinion.com
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
