removing ign lock
is there a way to remove the tumbler from ign on a 51 without the key? or d I just buy a new switch since I am going to replace all the locks anyway?
Re: removing ign lock
It should have a little hole in the face. If so stick a paper clip in it and with the key in it turn the switch on and it should pull right out.
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway |
Is there a lock on the glove box door?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
I'm not familiar with the lock cylinder on a 51, but all others I've messed with were more cooperative after running a 1/4" drill bit in about 3/4". After that the paper clip in the little hole and a screwdriver works.
OK, and I just happened to get a new drill for Christmas !
