12-25-2010, 06:06 PM | #1 |
Simple front bag setup-Some opinions and help?
Hey everyone, Merry Christmas!
I had some questions about bags as I do not know much at all about them, I've read a lot but most set ups are full air ride laying frame or something. I'm thinking of a much simpler set up so here goes.... Can someone school me on what would be a good idea, pros and cons, /plan/work/cost for putting some bags up front on my 2wd 1980 rcsb? I was thinking of doing a 4/6 but with the LS oil pan and terrible roads in MA, I was thinking adjustability may be the better option? What do you think? Whats a good, simple set up? I keep hearing about schrader valves? I already have a flip kit for the rear and DJM 3in drop spindles for the front. Thanks for any help!
1979 c30 3+3 dually 1946 GMC |
12-25-2010, 09:16 PM | #2 |
Re: Simple front bag setup-Some opinions and help?
I don't know prices really because they change depending on where you buy.
But you will need: Air bags. Air lines and fittings. Plates or cups (which allow you to bolt the air bags to the lower control arm and spring perch. A compressor An air tank. And air valves (probably 1/4" or 3/8"). On the front You can get away with two valves. One to let air in, one to let air out. But the prefered method is two valves for each wheel. I hope this helps Posted via Mobile Device
Max Max's bagged 81 81 rcsb bagged, 22s, build in progress 09 ext cab, 24" U2's, DD sub/amp |
12-25-2010, 11:18 PM | #3 |
I just checked out ***************** and quoted parts for a front bag setup and the absolute cheapest (without compressor and tank) is around $360 bucks, and more realistically you'd probably have to spend $450 at the low end.
12-26-2010, 01:36 AM | #4 | |
12-27-2010, 04:18 PM | #5 |
Hm, I didnt realize the f-body pan was that useful. Maybe I'll have to rethink, I dont know, Im new to all this lowering stuff so I was thinking that might be the way to go. Do you mean helper bags? Do those raise and lower the truck at all or just help with towing?
12-27-2010, 06:09 PM | #6 | |
http://kieth.smugmug.com/Trucks/66-G...28723713_zsmuL Good Luck |
12-27-2010, 06:16 PM | #7 | |
is a fungineer
2003 S10, 2.2 auto- the daily driver, currently with a 2"/2" drop and some minor engine bolt-ons 1978 Impala 2-door, race 350/T350 - the new race car, in progress 1968 Chevy C10 longbed- 3/5 drop, currently undergoing a heart transplant |
12-27-2010, 06:45 PM | #8 |
Actually we have a kit includes bags, brackets, shocks and fittings for 300.00. Then depending what you want to do for the control system it can go up from there
12-27-2010, 07:09 PM | #9 |
Happy to be here
Very true. Just Google them and see what you get.Here ya go. Buy quality components from a reputable company.
12-27-2010, 07:15 PM | #10 |
12-27-2010, 07:30 PM | #11 |
Key City Truckers Abilene, Tx. USAF AMMO 87 C10 (Beulla) 87 Buick Regal Turbo T (Tiffany) |
12-27-2010, 09:20 PM | #12 |
X3
The front cups aren't even the right size for our trucks that they send you. |
12-28-2010, 01:22 AM | #13 | |
A 4" front drop is 3" spindles & a 1" dropped coil. You could use bags in place of the coils but it's definitely not necessary. Bags could be used in this application to raise the vehicle for obstacles if that's the goal. I just don't think it's practical to expect to be able to raise it up fast enough to avoid road rash when driving. Slow/no speed? Sure. At speed w/consistency? I doubt it. As others have warned..... avoid AIM/Chassis Tech.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-28-2010 at 01:23 AM. |
12-28-2010, 01:28 AM | #14 |
Yeah I have a 3/5 kit that came with the truck, from DJM. It consists of 3in drop spindles and a flip kit. After looking at some pics I think it looks weird sometimes and want the front to sit just a little lower than the back....but the DJM kit looks like the front is a little higher which i hate (our fenders don't help) so i was just thinking of putting bags in the front so i could get the front height perfect with good ride quality. but keep the opinions and options coming because i haven't made up my mind and am still learning, very new!
12-28-2010, 12:05 PM | #15 |
Happy to be here
If I were just looking for a bit more drop up front, I would consider cutting a half or full coil from the stock spring. Follow that with a good set of shocks and you should be fine.
12-28-2010, 12:17 PM | #16 |
12-28-2010, 12:22 PM | #17 |
Happy to be here
I said "if" didn't I...
12-28-2010, 01:17 PM | #18 |
