Anchor point for shoulder harness?
what has everyone done to create an anchor point when adding a shoulder harness seat belt? Reinforce it with a plate?? I was going to hammer small piece of plate to match the contour, slide it up behind the cab wall, weld it through spot weld holes.
292 + TKO500 |
Re: Anchor point for shoulder harness?
One of the guys did it when he made his a big window. I am going to make mine a big window and put it behind the panel when I take it off.
Bad Decisions usually make for Good Stories. |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Yep, That's what I would do. You should be able to reach up there from the opening below with maybe a piece of steel temporarily tacked to the plate. Then break it off after it is welded to the sheetmetal.
SO-CAL sells plates with nuts welded, They are cheap and worked perfect I used them on my 66. Drill hole from inside cab through superficial panel and slide plate up behind panel just drilled with hand and thread bolt. Driverside had to remove fillerneck so my arm would fit.
I LOVE BURNOUTS ![]() ![]() NO BOZO's |
Thanks guys!
292 + TKO500 |
Hardwaa, Do you have any part number for the So-Cal anchor plates, I looked on a couple of So-Cal site and have not found them. They look like something I would like to buy.
Taclem |
![]() Join Date: May 2007
wana see myself
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
![]() Join Date: Jul 2009
I bought my seat belts from Juliano's and the anchor plates for the shoulder belts came as part of the mounting package. I'm sure you could get them there also.
I did mine exactly the same way as Hardwaa did. There's no need to weld the plate in place. Just slide it up behind the hole you drilled, and thread the bolt on. Skinny arms help, or a tacked on "reach extender". The inner sheetmetal panelis pretty strong. It might deform a bit in a serious crash, but by that point you'd have bigger problems anyway.............
Ralph |
Desert Dweller
Great info guys. I'm planning to install new seat belts in my 66 and this is how I will do mine as hardwaa suggested.
The So-Cal info is on the last page of this link http://www.so-cal-az.com/uploads/Int...pg_114-117.pdf I'm gonna pick up a set tomorrow ![]() Tony Posted via Mobile Device |
AZ66GMC Thanks for posting a link. I am sure other venders have the same part.
![]() Join Date: Sep 2006
I had to use a stick with the piece taped on because my hand/arm would not fit.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 12-28-2010 at 12:51 AM. |
#13 | |
#14 |
Sure, should be the same. As 777ralph pointed out, there is no need to weld anything, just hold the backing plate in place at the time of install and your done.
Look at the pictures in the thread for placement, about 1/2 way up on the small rear window. Drill 7/16" hole, that is the size of the anchor bolts commonly used.
292 + TKO500 |
#15 |
Thanks for the reply. This will be my next project for the truck.
#16 |
Mine is a 64. Worked great. I mounted mine back a little further toward the corner, but that's just where my arm fit. Put it high enough so it's above your shoulder, though. Check a new car for placement. Taking the tank out is the hardest part. With a bit of rod tacked on to the plate you might not have to do that.
Ralph |
#17 |
![]() Join Date: Jul 2011
Ebay has them. I'm putting bucket seat in my 65 and I bought a set of 3 point seat belts with all three mounting anchors reinforcements in a package deal $119 shipped.
