Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 12-25-2010, 07:23 PM   #1
Eyegore
What Hump?
Eyegore's Avatar
How to bleed a 4 ton floor jack?
As the title says I need help bleeding my floor jack. My floor jack is finally loosing its lift, I have not found any puddles of hydralic fluid though. And before anyone says it -YES I DO USE JACK STANDS ALWAYS!!! My dads boss was killed many years ago from a car falling on him so I know how important they are.
The jack goes back down even when there is no load on it so I'm guessing that I need to bled and perhaps replace the fluid. I've had this jack close to 15 years, I purchased it from a place called APCO and it has always been very reliable. The fill location is on top and I'm waiting till monday to get the proper hydralic oil for it but for now does anyone know the proceedure for bleeding it?
Thank you ahead of time.
Tom
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 12-25-2010, 11:36 PM   #2
crushermechanic
crushermechanic's Avatar
Re: How to bleed a 4 ton floor jack?
sounds like either the valve is leaking or the piston packing is bad. either way the jack will probably need to be resealed.
crushermechanic is offline   Reply With Quote
Old 12-26-2010, 01:41 AM   #3
Eyegore
What Hump?
Eyegore's Avatar
no apparent places where it has leaked, but I know there is a way to bleed the cylinder, that is what i need to know how its done.
Lil red 86 c-10
99 Sub
Old 12-26-2010, 05:28 AM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
You should be able to see a fill plug on it and fill it "Usually" until it is even with the hole.Pumping it up and letting it down a few times usually bleeds one.crushermechanic does have a point.A jack does not need to be leaking externally to leak past the seals internally.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-26-2010, 10:22 AM   #5
cdowns
cdowns's Avatar
always just filled to the hole,pumped up with a load a few times then topped off after those few cycles
have also had no sign of leak and the jack slowly lost jaking ability being 20years old i just replaced the jack that time
Old 12-26-2010, 07:53 PM   #6
cableguy0
Just because its not leaking to the outside doesnt mean its not leaking internally causing the pressure loss allowing the cylinder to bleed down. Your jack is worn out time for a replacement before something bad happens
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
