Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-26-2010, 01:02 AM   #1
85burb
85burb's Avatar
Constant fuel pump voltage?
I have put this in this area cause i tend to think more of you may be running electric fuel pumps then other sections on here. I have a question...I have just installed a summit (looks just like the holley) elec fuel pump in my truck in preperation for my engine swap. The pump sounds like the rpm changes a lot. I mean when truck is at idle is a lot slower the if i idle it up a bit. That i beleve will change my fuel psi to the regulator and will intern change my fuel psi to the carb. I would like to know if there is any way to make pump have a constant speed. Or i may just be crazy. I am having a hard time getting my psi at the carb to stay constant. If i start it cold and the fast idle cam is kicked in it is at 9 psi but when it warms up it is less. I beleve it to be something with the voltage at the pump. Any help on this would be appreciated.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 12-26-2010, 03:48 AM   #2
BarryB
BarryB's Avatar
Re: Constant fuel pump voltage?
Have you checked your voltage at the pump? one way to get costant voltage is to take it directly from the battery with a switched relay in line.
As for the pump, I'm sure someone more knowledgable about them will chime in.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 12-26-2010, 11:16 AM   #3
Marv D
Registered Truck Offender
Marv D's Avatar
DEFINATELY run a MINIMUM 12g hot from the battery to a relay near the pump to feed the pump. Low voltage is what causes the pumps to burn up. I'll bet a dollar to a donut you see the 'sound' of your pump is identical with the sweep of the amp/volt gauge in the dash!
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
