Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 12-26-2010, 01:33 AM   #1
geoff.clark
SheetMetalNoob
geoff.clark's Avatar
Buying a new Air Compressor
I am biting the bullet and going to get a new air compressor. I currently have a small 2hp 20 gallon tank. Can't keep up with much...
I leaning towards this...
http://www.northerntool.com/shop/too...5171_200365171
Any thoughts negative or positive.
Thank you for any feedback.
Geoff Clark
Classic Truck NoOb
83 Chevy Custom Deluxe I6 250 lwb (aka) Trash Runner
geoff.clark is offline   Reply With Quote
Old 12-26-2010, 02:05 AM   #2
Maxxd07
Maxxd07's Avatar
Re: Buying a new Air Compressor
Should do ok. If you ever decide to run a blaster or paint with it etc... it should cover it. I have a IR I bought from northern about 5 years ago and love it. The specs are about identical to this one and the only reason for the IR was free shipping! I dont have anything to challenge it yet but hope to get a blast cabinet soon.
Couple 80s
Couple 70s
One 68
Maxxd07 is offline   Reply With Quote
Old 12-26-2010, 11:10 AM   #3
geoff.clark
SheetMetalNoob
Thank you for the comments. I am trying to get the right compressor so I can paint. From what I have been reading I need a minimum of 80 Gallon 5HP.
Geoff Clark
Classic Truck NoOb
Old 12-26-2010, 04:59 PM   #4
greene
tractor supply has a 5 hp 2stage ingersol rand 80 gallon for 999.99
greene is offline   Reply With Quote
Old 12-27-2010, 12:36 AM   #5
trz1000
I have a single stage 3 piston 18cfm from these guys, http://www.eatoncompressor.com/ made in USA if you care about that sort of thing.
I've had it for probably 7 years with no issues. I'm happy with it but if I had to do it again, I'd get a two stage. I use if for air sanders, die grinders, and even painted a few things with it. I've never out run it but it's hard to buy an air compressor that's too big.
trz1000 is offline   Reply With Quote
Old 12-28-2010, 01:54 AM   #6
72lb4x4
Check the motor specs and pump RPM. 5HP is pretty meaningless when it comes to compressors. Compare CFM @ some PSI. The 5HP Baldor motor on mine is rated at 23A @ 230V.
You might troll CL for a while to see if you can't find a quality used compressor for less money. For example: http://dallas.craigslist.org/ftw/tls/2130903454.html
Its kind of a funny example since its duplex but I'd guess its an expensive compressor if bought new.
72lb4x4 is offline   Reply With Quote
Old 12-29-2010, 03:02 AM   #7
Gobbles
Gobbles's Avatar
HP and size aren't as important as CFM as 72 mentioned. I believe that sand blasting requires 11 CFM at 90 PSI, not sure about paint but I think a good HVLP gun has a lower CFM requirement, but for solid passes you would need a larger reservoir ie, the 80 gal. my 0.02!
Trevor
"You already said spite"
Gobbles is offline   Reply With Quote
Old 12-31-2010, 12:39 AM   #8
geoff.clark
SheetMetalNoob
I did some research on Eaton and spoke with them today. Great people over there and apparently great product. I have decided to go with this one.
http://www.eatoncompressor.com/catal...47/6474775.htm
Thanks for pointing me in the right direction.
Geoff Clark
Classic Truck NoOb
Old 01-01-2011, 10:22 AM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You're definitely buying a hell of a compressor. 19 SCFM will run pretty much anything you'll likely ever need in the future.
Old 01-15-2011, 01:25 AM   #10
johnsons63
I went with the husky set with the air tools (air ratchet, air hammer, impact gun) from home depot years ago and I love it. I have no reasoning to spend any more then that...
_____________________
OEM Bed rails, OEM Brush guard, Magnaflow 22" with Gibson pipes, PRG Mini-lift, Cooper Discoverer S/T 35x12.50x17, Lund hood protector, Hadley, Ventshade in-channel window visors, Bushwacker Extenda-flares, front window tint.
johnsons63 is offline   Reply With Quote
Old 01-15-2011, 12:21 PM   #11
cdowns
cdowns's Avatar
B4 you turn a new compressor on you should check the oil level
