#1 | |
brake issues.
so today i hopped in the truck and let her warm up, because i needed to move her for the snowstorm thats headed our way. reguardless, i was backing it to the spot i wanted it, and hit the brakes, and the front right tire skidded. at that point, i wasnt where i wanted to be, so i pulled forward, backed up, and it did it again. it happened over 10 times, and i need to know whats wrong with them, because i really dont want to go the replace every part route. thanks in advance!
1967 K-10 4x4 with a 3" lift and 35" BFG mud terrains ![]() Quote:
![]() want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there |
Re: brake issues.
best way is to take tires off and get inside the brake drums and inspect your brakes
#3 | |
Re: brake issues.
i did that last week. the drums were replaced less than a year ago, and the pads are almost new too.
Re: brake issues.
they must b fine then nothing wrong with them
#5 | |
Re: brake issues.
im not an expert at brakes, but they are definatly NOT fine. when i say the tire skids, like it throws the whole truck around. and only that tire locks up. and if it matters, they are manual brakes, 4 wheel drum
![]() want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there Last edited by jakeblues652; 12-26-2010 at 04:25 PM. |
Re: brake issues.
Sounds like a leaky wheel cylinder even though you have new shoes and drums. Look for any evidence of brake fluid on your rim or tire. You might need to pull the drum off. If you find brake fluid you'll need to replace the cylinder and the shoes on that side.
#7 | |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: brake issues.
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
#8 | |
Re: brake issues.
can you give me a step by step? i just dont want to mess anything up.
Re: brake issues.
Almost sounds like a primary shoes installed on one side.
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: brake issues.
leaky wheel cylinder gets my vote.
Re: brake issues.
+3 on leaking wheel cylinder as a likely culprit.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
Re: brake issues.
I vote on the wheel cylinder also. My truck did that skid thing a few weeks ago and when I checked one of the front wheel cylinders, a little bit of brake fluid spilled out when I peeled back one of the outside pieces of rubber. When I took the wheel cylinder apart there was surface rust on the inside bore and cup, in addition to the small leak-by. I went ahead and replaced both front cylinders and the truck is braking good.
69 SB GMC LWB Fleetside 350, 09 Pontiac Vibe 2.4 liter |
#13 | |
Re: brake issues.
do i in fact need to replace the shoes on that side? like i said they're almost new.
#14 |
laying low
![]() Join Date: Mar 2001
Re: brake issues.
There is no way of completely removing brake fluid soaked into the shoes if that is the case. And no more than a set of shoes cost why would you take the chance?
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#15 |
Re: brake issues.
I would also add that it could be something other than the wheel cylinders. As I previously said, I had replaced the front wheel cylinders and it was braking good. But then, today it skidded again. I decided to check the back cylinders and one side looked okay. But the other side there was oil all over the place, not yet enough to leak out of the brake drum, but enough to coat everything. The axle seal is leaking and I think this is the real cause of the occasional skid, at least in my case. Good luck.
#16 | |
Re: brake issues.
its not an occasional skid. its every time you stop unless you go REALLY light on the brakes. and when i mean really light, like on a flat area taking 60 feet to stop and it wont do it. i plan on tearing it back apart tomorrow to see if that is that is whats wrong.
#17 |
It's all in the timing
Re: brake issues.
I never take shortcuts when it comes to brakes,I would tear both sides down.Replace the wheel cyl. and hoses and inspect to see what else needed to be repaced.My truck would pull to the right real bad everytime I even touched the brakes.I rebuilt both sides and now I can slam the brakes and let go of the wheel and it will stop strait asd an arrow.
#18 | |
Re: brake issues.
wheel cylinder=replaced and bled, and still same results. have the DR side WC too, gonna replace that tomorrow, if we arent rolling in the snow all day. any other suggestions?
#19 |
Re: brake issues.
replace bolth front hoses
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
#20 | |
Re: brake issues.
the flex lines were recently replaced with metal braided line. and the front lines from the proportioning valve also look newer.
#21 | |
Re: brake issues.
okay, so both WC's = replaced. still same problem. bled the brakes and all that jazz too. some pedals, ill have full pedals, and other pedals i need to pump it before theres any pressure. it was the same before, and i could have sworn that this would fix it. whats next, proportioning valve?
#22 |
Re: brake issues.
Sounds like the MC to me.
__________________________________________ Sean 1972 C20 2005 4Runner ![]() |
#23 |
its all about the +6 inches
Re: brake issues.
the master wont make one side lock and not the other.
adjust the shoes to where they are dragging ever so slightly and test drive. |
#24 |
![]() Join Date: Oct 2009
Re: brake issues.
Double check your wc, if you put in a rebuilt part doesn't mean it's good. I've had one caliper last a year and then 4 more until I got one that was good. If they are good, it sounds like the MC.
#25 |
Re: brake issues.
If the brake shoes were saturated with brake fluid,... they will still grab.
Change the brake shoes, and clean the drum prior to reassembly..
