Old 12-26-2010, 07:33 PM   #1
glhman222
1979 chevy spindles question
i know that lift spindles are not being made anymore but i was wondering if you could use say a 3 inch lowering spindle and flip it over and use it on the other side? is this even possible?
just wondering since im looking for about a 6 inch lift with just suspension modifications and then add on a 3 inch body lift for 9 inches total for that prerunner look
please don't mention anything about 4wd or why lift a 2wd in here.
i have my reasons
truck is a 1979 chevy c10 lwb fleetside 350/350 combo, 4.11 gears, would like to clear 38's
1979 Chevy C10 Longbed
glhman222 is offline   Reply With Quote
Old 12-26-2010, 08:01 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 1979 chevy spindles question
The ball joint tapers would be wrong.
(top vs bottom)
And the tie rod arm of the spindle,... would be in the wrong spot,... and the taper would be upside down.
Keith
Convert to disc brakes.
Old 12-26-2010, 08:08 PM   #3
63chevyll
gets board easy.......
63chevyll's Avatar
Nope, won't work. you could try some 88+ 2wd spindle. I've thought about trying thembut not sure what to modify
63chevyll is offline   Reply With Quote
Old 12-26-2010, 08:12 PM   #4
glhman222
i read about a guy trying to use a 88+ spindle but he ran into problems with the ball joint i think
Old 12-26-2010, 08:28 PM   #5
lolife99
lolife99's Avatar
Swap the upper balljoint to the 88-98 balljoint.
Bolt in a (3/4-ton) 73-87 lower a-arm,... (which will allow the use of a 88-98 lower balljoint).
I'm not sure about the outer tie rod ends.
There's a thread on here about using 88-98 lift spindles on the 73-87 trucks.
Keith
Old 12-26-2010, 09:05 PM   #6
glhman222
ive searched and searched but have found no one that has successfully done it not saying no one has but ive searched for a few hours with no luck or dead ends
Old 12-26-2010, 09:11 PM   #7
lolife99
lolife99's Avatar
Looks like member MickMc did it back in 2009,... but that's where the thread ends.
http://67-72chevytrucks.com/vboard/s...d.php?t=323240
Keith
Old 12-26-2010, 09:14 PM   #8
lolife99
lolife99's Avatar
Look at this thread also.
Dinos63's truck is picture with his lift spindles.
http://67-72chevytrucks.com/vboard/s...d.php?t=405623
Keith
Old 12-26-2010, 09:28 PM   #9
glhman222
wow thats 1 sick truck, thank you for some more information, hopefully my truck will be that high one day
Old 12-31-2010, 12:50 AM   #10
63chevyll
63chevyll's Avatar
this has me interested.
I have some 78 3/4 ton arms and 88 spindles. Im gonna check it out. i didnt realize it was that eazy.
i guess the tie rod end could be re tapered to the next size. if i remeber ringht the 73-87 outer tie rod ends are pretty big, will will have to compare to a 88 spindle
