12-26-2010, 10:28 PM | #1 |
Moderator
Help: I need to Identify an OEM Blower Motor for A/C truck
Hello! I am looking at buying an OEM blower motor for my air conditioned truck and I believe that there is an A/C version, and a non-A/C version. The person from whom I am looking at puchasing the blower motor is not sure, but has indicated that his "Fan unit is marked with a big " H " (Harrison, I think) and has # 3157437 on it."
Also, his has a plastic fan, wheras my original had a metal fan. If you know for sure, please let me know. I have long since disposed of my original blower motor, and kept my fan. However, my fan needs replacing. I want to go OEM, not aftermarket, which is why I am bothering with a used OEM. Thank you for you help.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
12-27-2010, 07:06 PM | #2 |
Moderator
Re: Help: I need to Identify an OEM Blower Motor for A/C truck
Please, someone must know...
12-27-2010, 07:57 PM | #3 |
Unless you are trying to keep the truck 100% original, just about any fan motor will work, as they turn one of two ways, depending on the direction of your fans blades. Ask the seller what direction the blade points at 12 oclock when looking at the retaining nut (Dont let on as to what direction yours points). If its pointing the same direction as yours it should work.
12-27-2010, 08:26 PM | #4 |
The difference between the A/C motor & non-A/C motor is the little rubber tube that attaches to it. The non-A/C motor is solid with no holes, whereas the A/C motor has a hole in the side of the case with the little rubber tube that pops into it. I forgot exactly why it has the tube. I think it might be to draw in fresh air to keep the motor cool or something.
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS -1983 Chevy Silverado C1500- 383 stroker, TH400 -1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears -And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket "The only thing we have to fear is fear itself." -FDR (and maybe rust too) You've gotta be able to stop and steer before you can go fast! |
12-27-2010, 08:31 PM | #5 |
It is a little hard to see in the picture but the AC motor is larger and it has a short hose attached to the motor which runs to the housing.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
12-27-2010, 10:11 PM | #6 |
yep that is what i have found the a/c motor runs faster too dont know what the tube is for good luck
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
12-27-2010, 10:24 PM | #7 |
Moderator
Thank you all of you for responding. You have been a tremendous help.
02-03-2011, 10:22 PM | #8 |
Hi buddy is this one you need? this is from an s10 chevy pickup truck.
A/C blower motor wheel but i am not really sure if that match the part number of what you are looking for. i just found it on this site A/C blower motor wheel Last edited by masterjohnson; 02-05-2011 at 03:08 AM. |
