![]() Join Date: Sep 2005
Optional oil filter
I am working on a couple of projects where I am adding the optional external oil filter to a six cylinder motor. I have most everything I need to add this except the small cast fitting that screws into the block. I believe these are the same for 1961 and 1962 years. I want to keep the factory look for these but can't find the correct fittings. They are about 1.5 inches long have two female fittings and one male fitting that screws into the block. Does anyone reproduce these fittings?
James |
Re: Optional oil filter
Most of the 235 - 261 s that I have seen just had brass fittings 1/8 npt to inverted flare and a brass hose barb with a sleeve (most of these were canadian trucks so maybe they are different)
62 GMC 910 short fleetside 454 super t10 14 bolt w/gov lock 70s c20 front discs (built in the 80s) 65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck) 63 GMC 950 camperized school bus, (Gus the bus) 350 4speed 2 speed rear 64 GMC 950 "spare" bus 283? 4speed detroit locker 53 GMC 1ton dual wheel bus 78 GMC c25 short course off road race truck(son's truck) 355 th400 14 bolt (www.wheel2wheel.ca) 88 Peterbilt 379 longhood (hauls race truck) ![]() ![]() ![]() ![]() |
Thanks, I have seen at least a dozen on cars or trucks that I know are factory correct. Every one of them has the cast fitting I described. I will see if I can get a picture.
James |
