Old 12-27-2010, 04:15 PM   #1
69yokel
33"s on without lift
Are there any issues with running 33 inch tires on a 72 4x4 without a lift? I was thinking on going from a 265/75-16 to a 285. Seems like it should fit with little to no mod. If anyone has any pics of this type of setup it would help greatly.
69yokel is offline   Reply With Quote
Old 12-27-2010, 04:32 PM   #2
67gmcstepside
Re: 33"s on without lift
I have 33's on a non-lifted 67 4x4. I originally had 33x15x12's and they rubbed, 33x15x8's are on now and I have no problem. You should have no issue with a 72.
15x12's
15x8's
67gmcstepside is offline   Reply With Quote
Old 12-27-2010, 05:14 PM   #3
Altec
Getcha Pull
Altec's Avatar
15x12's
[IG]http://i421.photobucket.com/albums/pp294/donwsmith69z/67%20GMC%204x4/IMG00088-20101204-09291.jpg[/IMG]
15x8's
[IG]http://i421.photobucket.com/albums/pp294/donwsmith69z/67%20GMC%204x4/newrims.jpg[/IMG]
You had me scratching my head for a minute there. I was thinking "Who makes a 15" wide tire?!"
The 265 would probably be the way to go. It is ever so slightly shorter, but where the 285 is a 12.5" width tire, the 265 is a 10.5". So if you ever flex it out, the tires won't rub when turning. Just my thought.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 12-27-2010, 08:09 PM   #4
305/75s are 12.50/33s,which measure closer to 32.5, and they will fit with no lift. With 8" rims will clear best. 10" will let them rub some. 285/75s are about 32.5" tall and about 10.00 wide. The tread width is about 8.25. They will work out better. Have you considered the BFG M/Ts in 255/85? They are right about 33 and closer to 9" wide.
Old 12-27-2010, 08:15 PM   #5
SeventyOne
Before the resto my Blazer ran 33x12.5 on 15x8 wagonwheel rims w/ very minor rubbing only at full steering lock.
SeventyOne is offline   Reply With Quote
Old 12-27-2010, 08:30 PM   #6
CG
BlahBlahBlah
Here is mine with no lift and 33 12.5 16.5 Sorry for the big pic its the only one I could find on this computer. 71K20
Old 12-28-2010, 01:14 AM   #7
Permafrost
Permafrost's Avatar
Not to jack the thread but....
CG ~ That's a gorgeous truck! The 33's fill the wheel wells nicely and I dig the wheel and cap combo!
Too Many Projects:
'50 GMC
'62 Nova drop-top
'68 K10
'68 Chevelle SS
Permafrost is offline   Reply With Quote
Old 12-28-2010, 08:37 AM   #8
12.50/33s on 8.25 wheels:
Old 12-28-2010, 09:54 AM   #9
69yokel
thanks everyone. Im sure now they'll fit fine.
Old 12-30-2010, 02:14 AM   #10
CG
BlahBlahBlah
Hey thanks, but trust me my truck looks about 100 times better in this pic than it does IRL =)
Old 12-31-2010, 05:12 PM   #11
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yea I have ran 33's with no lift on newer stuff and only had them rub occasionally haha. Think you should be fine unless your extreme offroading it.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
