12-27-2010, 09:18 PM | #1 |
project "SHORTHORN"
well this build started when i sold my 72 short bed.I went about a week and got the itch for a new project I called a guy on cl about some parts went to his house and saw he had a 1969 longhorn in his yard. Asked him how much and he said $275 bucks so thats how it started. The truck is a 69 longhorn with a clean body but no motor and tranny orignal 402/400. Trucks been sitting since 1992 so once i got it home i blew it apart im keeping the sheetmetal but everthing else has got to go. I scrapped the rolling chassis
for a total of $215 bucks so im into it for $60 not bad. The plan is to build another short bed as cheap as possible and im off to a good start. |
12-27-2010, 11:20 PM | #2 |
Re: project "SHORTHORN"
Subscribed!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
12-28-2010, 12:16 AM | #3 |
ill be following this one man wish I could find a deal like that here on the east coast
1970 C-10 CST 2003 Silverado 2004 Avalanche LTZ |
12-28-2010, 02:10 AM | #4 |
cool what is your plans with the spot light
12-28-2010, 07:09 PM | #5 |
Im not going to use the spotlight planned on removeing it and welding up the holes
its kind of a shame because its in pretty nice shape Posted via Mobile Device |
12-28-2010, 09:41 PM | #6 |
More Cowbell....
Chop that sucker to bits, then put it back together...but better!!! Awesome find.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
12-29-2010, 11:06 AM | #7 |
Cool can't wait to see more.
12-29-2010, 10:00 PM | #8 |
picked up my shortbed frame its in really nice shape just really crusty
12-29-2010, 10:08 PM | #9 |
Tot Roddin'
Looks like a fun project, subscribed.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 12-29-2010 at 10:08 PM. |
02-03-2011, 09:35 PM | #10 |
well I finally got my frame all cleaned and painted and started reassambly.
Only took 4 trips to the hardware store to get all the right hardware! Picked up some TJ springs for the rear only 25 bucks Still need some 5 lug axles and drop spindles to get it back on the ground |
02-03-2011, 09:44 PM | #11 |
Lookin good..
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629 1969 custom/10 swb--SOLD 1968 swb 50th anniv.--SOLD 1967 camaro ss/rs..LS-6-speed, 16-year long project 1956 chevy nomad 1955 chevy 210 2-dr sedan 1978 el-camino ss 1-owner |
02-03-2011, 10:07 PM | #12 |
6>8 Plugless........
Very nice! Are you cutting down the Longhorn bed to make your short bed?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
02-03-2011, 10:40 PM | #13 |
also cleaned up the factory fuel and brake lines I used a wire wheel to clean them up then steel wool and finaly some rattle can clear coat
I used the factory 3/8 fuel line from the longhorn because im planing on running a big block Yes my plan is to cut down the longhorn bed into a short bed i dont care for the wood bed to much but Ill make it work |
02-03-2011, 10:50 PM | #14 |
Formerly- 1972SuperCheyenne
Looking great.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
05-09-2011, 09:26 PM | #15 |
made some progress but it ends up my frame ie a 67 so it has a wide uper frame rail so the factory big block mounts i scored dont fit.
im planning on measuring a 68 up frame and cutting mine down so motor mount towers fit. Only bad part is i already painted the frame. |
09-06-2011, 09:54 PM | #16 |
progress pics, roller almost done cut 67 frame to match later frame so
big block mounts fit now. also painted motor black but i did'nt like it so i pulled it all back apart and painted it orange much haipper now. Going to start work on cab hopefully weather will start cooling off. |
09-06-2011, 09:57 PM | #17 |
more pics cab on roller ready to strip down
11-27-2011, 12:51 PM | #18 |
started cutting down longhorn bed found a steel floor from a long bed to cut down. The floor is done and one bed side. I set bedsides next to each other to show length diff -26 inches
11-27-2011, 12:55 PM | #19 |
a few more going to start other side today
11-27-2011, 01:34 PM | #20 |
What did you you use to cut those bed sides?
11-27-2011, 01:57 PM | #21 |
11-27-2011, 02:52 PM | #22 |
good deal .. nice project looks like you did good job on shorting the bedside.
11-27-2011, 03:39 PM | #23 |
Nice work - subscribed
66 GMC Suburban Custom 66 Chevy K10 Suburban |
11-27-2011, 04:12 PM | #24 |
Looks great !!!
1964 C10 SWB original 1970 SS El Camino 1964 Impala SS http://67-72chevytrucks.com/vboard/s...d.php?t=649951 |
11-27-2011, 09:10 PM | #25 |
driver side cut down
