Old 12-28-2010, 12:19 AM   #1
Fat Mike
Fat Mike's Avatar
Is this too much?
I hate to use other peoples work as examples but would possibly like to try this. This subframe job was very interesting to me. This subframe is installed inside of the frame rails, kicking it up very high. I like this idea because you would have a huge weld area, then you can box it in, and have it very stable. The only thing is with bags would it sit so low that it would scrapped when aired out.
Fat Mike is offline   Reply With Quote
Old 12-28-2010, 12:40 AM   #2
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Re: Is this too much?
If you Z'd the front where the far front body mounts are and bed mounts are it would be perfect. A subframe and a Z job all in one. IMO
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 12-28-2010, 12:43 AM   #3
Tchia65
I have never used a Camaro sub on these trucks, but I do have a Camaro. That looks like it would be ok for a static drop, but too low for bags. IMHO
1958 Fleetside shortbox
1965 Malibu SS
1970 Camaro RS
1972 Malibu wagon
Tchia65 is offline   Reply With Quote
Old 12-28-2010, 12:53 AM   #4
Fat Mike
Fat Mike's Avatar
I diffently wanted to use bags so it would be to low. Thanks for the info!
Old 12-28-2010, 11:49 AM   #5
thirdstreettito
Resident of Here
You can us bags. Just make sure you install the bags/wheels before welding the front end on. That way you can cut, grind, measure, etc so it doesn't drag when fully aired out.
~Bradley~
Miss having a truck
Old 12-28-2010, 12:51 PM   #6
1955 Eddie
1955 Eddie's Avatar
I used that exact setup on my air bagged 55.
[IMG][/IMG]
I left this image below full size so I just pasted the link to it. I included it to show you that I have mine dropped all of the way down. my lower A frame will touch the Camaro frame. This pic is pre bump stop so you can see them touch. You can also see a very small amount of clearance between the crossmember and the floor. Its about an inch off of the ground.
http://s107.photobucket.com/albums/m...rrent=41ea.jpg
Side View
[IMG][/IMG]
front:18x7 with 3.75" backspacing (235/40/18 tire) 25.40 in tall
rear:20x10 with 3" backspacing (315/35/20 tire) 28.68 in tall
I will say that the the exhaust is very close to the ground at full drop, about 1/2 inch off of the ground.(only at the collector, its fine past that).
[IMG][/IMG]
1955 Eddie is offline   Reply With Quote
Old 12-28-2010, 05:00 PM   #7
Kim57
Kim57's Avatar
That is a very nice truck.
Kim
Kim57 is offline   Reply With Quote
Old 12-28-2010, 05:52 PM   #8
Fat Mike
Fat Mike's Avatar
[IMG][/IMG]
Side View
[IMG][/IMG]
[IMG][/IMG]
Your set up is alittle different. Yours runs under the frame and the one i posted runs into the frame and sits in the frame.
Old 12-28-2010, 05:56 PM   #9
cajundragger
^^that is the best way i have seen to stub a frame. Take the "legs" from the camaro sub and butt them against the bottom of your stock truck frame.
cajundragger is offline   Reply With Quote
Old 12-28-2010, 06:01 PM   #10
Fat Mike
Fat Mike's Avatar
I was just looking for a cleaner look.
Old 12-28-2010, 06:04 PM   #11
cajundragger
dont stub it then.
Old 12-28-2010, 06:25 PM   #12
Fat Mike
Fat Mike's Avatar
Yeah I know but it sure would be nice to get all that stub inside the frame for a larger welding surface.
Old 12-28-2010, 07:25 PM   #13
Kim57
Kim57's Avatar
Mike
Looking at the first pics you posted it looks like the bottom of the camaro frame lines up with the bottom of the truck frame. Doing it that way should give a lower stance initially.
You may have to mock it up with the truck frame on top and then figure out how much lower it will be with them lined (the tires will be higher up in the fenders).
You should be able to run bags. I think it will just change the amount of air you will be able to have in them.
Kim
Old 12-28-2010, 09:00 PM   #14
jjjmm56
jjjmm56's Avatar
Mike I'm with Eddie, setting the sub under the stock frame is the way to go. I 1st did it this way 20 yrs ago and still do. I know in some of your other posts you were asking about camber angles. Doing it as Eddie and myself has this is not an issue, but remember when using bags camber changes as the body angle changes. This is why you need to have an alignment at a set ride hight. Stacking the frame can be completed in a weekend, my 1st one took me that long and I did it by myself. When running bags I set bumpstops front and rear so when aired out my rockers are 1/2" off the ground, at this point my frame is 1" from hitting the ground. I can drive my truck in a straight line with no air in the bags. I don't know how to link somthing from another site but on the H.A.M.B. site there is an extensive writeup on this type of swap. Just remember the hardest part of this whole swap is making that first cut, after that it's a peice of cake.
jjjmm56 is offline   Reply With Quote
Old 12-28-2010, 09:27 PM   #15
S10Fan
Old Heap Driver
Here ya go.................
http://www.jalopyjournal.com/forum/s...light=subframe
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
