Old 02-28-2002, 09:36 PM   #1
high sierra
Post warmup part II
i have two questions. it is cold here in michigan. i have a 350 w/ 4spd auto w/ od. when it is cold the trans will slip when going from 1st to 2nd. also is there anything i can do to help truck run better in cold? should i have trans looked at?
mike
high sierra is offline   Reply With Quote
Old 03-01-2002, 07:14 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Post
Mike,
The problem is the cold weather. I would warm up the truck to at least 100 degress before driving. Heat the truck more if it's extremely cold. Oil flow in cold weather will hurt your tranny. Warmup the truck so the tranny oil will heat up. I had my tranny builder recommend 10 minutes of warm up during my tranny rebuild break-in. If the tranny shifts fine I would not worry unless the truck has a lot miles. Check your oil regularly and warm it up.
Gerardo
1983 Custom Truck
TX Plates: "BAD BOW"
http://www.geocities.com/abetterchemist/
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 03-02-2002, 12:19 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
While that is good advice, there is something not right. A tranny shouldn't slip, cold or not.
When was the last time you did a filter and fluid R&R? What color is your fluid now? Does it smell or taste burnt? How many miles on it?
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
Need to pick up the one ton Longhorn with a PONTIAC 350/350soon.
Thanks every one!
Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
