Drum drop spindles?
crazy for not wanting to upgrade to disc brakes in the front, I know, but I want to keep my 6 lug drums up front on my '70 SWB stepper.
I've got 2" drop springs and wanted to get an additional 2.5" drop with spindles without the brake upgrade for a total of 4.5" in the front. Is there anyone out there making these drop spindles yet? |
vw guy & now c-10 guy
![]() Join Date: Sep 2008
Re: Drum drop spindles?
not that i'm aware of. but you can keep 6-lug and go to disc. That's what i did. used parts from CPP
huh?
![]() Join Date: May 2000
I did the same, bought my kit from GMC Paul.
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
Happy to be here
![]() Join Date: Mar 2000
Not that I am aware of, and I doubt they ever will.
How about lowered lower control arms?
Has anyone gone this route? What are the good/bad? Who would you recommend purchasing them from? |
Grandpa in the rustmobile...
cut some coils and get the same result?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
VA72C10
![]() Join Date: Mar 2008
he's already got the drop coils and any more is a N0-no for scrub line issues. The drop lower control arms also have scrub line issues. They do allow you to keep your drums and drop an additional 2.5", but you will have problems if you ever have a flat or major problems if you ever have a blow out on the front while driving....
...or as mentioned...get 6 lug discs....but then you also need to consider your prop valve/master/booster situation...
Looking for a 67-72 swb or blazer project in or around VA. ![]() Last edited by VA72C10; 12-30-2010 at 11:45 AM. |
#8 | |
I remember a post where someone made their own drop lower arm by cutting out the spring pocket and welding in a new pocket out of large diameter pipe. Anyone else remember this thread? |
Hey VA72C10,
I was looking at this thread of yours http://67-72chevytrucks.com/vboard/s...=404906&page=4 and noticed you used lca's with the ball joint cut off and welded back on in a raised postion for a drop. any problems running like this? I would think the angle of the pocket would need to be adjusted. Any alignment issues? |
I think its kinda like a drop spindle (doestn change geometry, or you can adj. the geometry...?)
Dropped coils & dropped a-arms will put the spring pocket well below the scrub line if using 15" wheels.
#13 |
Happy to be here
It amazes me how much effort your willing to exert to avoid an upgrade that pertains to making your truck safer to drive.
#14 |
Discs will help alot.
Order some pre 71 drop spindles from ECE, and some 6 lug rotors and a prop. valve The rest can be bought at orielly, (calipers/pads/MC) If you REALLY have the $ to spend, rebuild the frontend. Or better yet get a 73+ k member and swap it all, 73+ DS seem to be cheaper and easier to find too!
#15 | |
Just trying to understand the options from all angles. I see this as a good thing-right? I don't really like any of the options I'm seeing that are available to keep the drums for the short period so I think I'll just do the 2" spring drop up front and get the 2.5" extra I'm looking for later with spindles along with the brake upgrade. Thanx for everyones help and concerns. |
#16 | |
VA72C10
I assume the advantage to a drop arm vs just a shorter spring is keeping the same compression ratio spring...does it also help keep the steering geometry better than a larger drop coil would?
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#17 |
why in the world would you want to keep drums for the front?
![]() There are much better solutions to your problem of wanting a lowered ride, that many companies have already spent R & D on. Problem solved!! |
#18 | ||
Swapping some shorter springs for drop is relatively cheap. Upgrading to discs @ the same time adds cost if the current brakes are deemed acceptable by the owner (no problem to solve).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-30-2010 at 12:57 PM. |
#19 | |
Oh, I understand the finance side of things completely, but when he already has a drop spring and wants to use a drop spindle, you gotta do what you gotta do. There aren't really any more options without spending money. But trying to come up with other solutions like a drop A-arm is just quite rediculous when there are much better/safer options out there. but hey,, thats just my opinon. |
#20 |
C-10 Club Member
Personallly I would say you should hold out and keep saving.....
![]() I wouldn't let my son ride in the truck other than around the block trips until I installed a disc/booster kit. imho it was just to dangerous driving at freeway speed in so cal with drums. On the flip side I encouraged wy wife to go on cruises and not wear her seat belt as she has a really good life insurance policy...lol ![]() ![]()
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels 1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910 |
#21 | |
Posted via Mobile Device |
#22 | |
VA72C10
#23 |
#24 |
#25 |
Happy to be here
Try comparing apples to apples. Yes there are vehicles with drum brakes that are capable of stopping just fine. In this case, replace inferior drum brakes with disc brakes is a HUGE improvement. Argue it from what ever angle you prefer, but the drum brakes on these trucks were never adequate.
