Old 12-28-2010, 10:46 PM   #1
keanevann
Difference between 67 doors and the rest (besides door handles)
Just like the posting says.....what are the differences between 67 doors and the rest (besides door handles)..... Thanks guys.... I saw someone saying something about the inner doors were different too. Im getting ready to paint my truck and I have replaced my passenger door with a 67 door.... If they are way different im gonna have call the body shop and have them put on another door that i have.... Thanks again!!!
keanevann is offline   Reply With Quote
Old 12-28-2010, 11:15 PM   #2
67chevy1series
67chevy1series's Avatar
Re: Difference between 67 doors and the rest (besides door handles)
port windows ,wing windows ,vent windows and there is an indentationin the door jamb for the trim
67chevy1series is offline   Reply With Quote
Old 12-29-2010, 12:07 AM   #3
jakeblues652
jakeblues652's Avatar
could someone post pictures of the differences? i am also interested.
1967 K-10 4x4 with a 3" lift and 35" BFG mud terrains
Originally Posted by Dan in Pasadena View Post
Did you figure out how to fix it?...I mean with other than a BFH?!
want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there
jakeblues652 is offline   Reply With Quote
Old 12-29-2010, 05:35 PM   #4
keanevann
I'm using all my 71 wing windows and hardware.... I'm just wondering if I'm gonna run into anything that is waaayyyy different....like something that would make my 71 parts not fit... Thanks
Old 12-29-2010, 08:19 PM   #5
I believe the wing vent assemblies interchange. I plan to do the opposite.
Old 12-29-2010, 08:26 PM   #6
Rob H.
Rob H.'s Avatar
I put in a vent window assembly from a 69 on my 67 with no problem. All looked pretty much the same except my 67 is a custom and had stainless trim and the 69 assembly was black, still looks alot better than all the silicon the PO had used to hold the vent window in place!
Rob
72 C/10 (under reconstruction)(destruction ? LOL)
48 Willys CJ2A
1952 Super "A" Farmall (Grandfather's)
Rob H. is offline   Reply With Quote
Old 12-29-2010, 09:16 PM   #7
sameyrasmea72
sameyrasmea72's Avatar
You should not run into any problems because the parts listed above will interchange. The big problem really is the door handle. Are you going to use an old 67 door handle? There is a extra plate welded inside a 67 door that will not allow a 68-72 or a NEW handle to mount correctly.
It sounds like you already knew this but I was curious as to how you were going to fix it because I almost did the same thing.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
