Old 12-28-2010, 11:49 PM   #1
72ArizonaBurb
Suggestions for removing or repairing cross member
Someone cut my cross member where the carrier bearing is suppose to hang to make room for a 1 piece drive shaft after putting airbags on. I want to return it to stock and have 2 options as I see it. 1) weld some new metal back in and drill holes for the carrier bearing mount or replace the cross member. I will have to disconnect the trailing arms, remove the emergency break cable and my muffler mounts if I replace it.
Does anyone know a good way to get those factory rivets out? It's in a tight place to get to so I don't know if I can get a grinder in there or not.
I'm open to any suggestions on what to do.
Thanks,
Keith
72ArizonaBurb is offline   Reply With Quote
Old 12-29-2010, 12:01 AM   #2
Classic Bowties
Always on the hunt...
Re: Suggestions for removing or repairing cross member
If my truck, I would replace the whole trailing arm cross member from frame rail to rail, I have had good luck using an air chisel on them factory rivets. Mel
Classic Bowties is offline   Reply With Quote
Old 12-29-2010, 01:42 AM   #3
Hoffa
Hoffa's Avatar
Another method I have successfully used is to use a grinder to remove the head flush with the frame and then tap them out with a punch. if the are touch coming out, I have also used a cutting torch to blow the center out and clean out with a punch.
That is my experience.
68 Chev SWB 2WD w/'95 LT1, 6spd, 4:56, 17" whls - family owned since 1973.
70 GMC LWB 4WD w/RAMJET 350, 4spd, 4inch lift, 33" tires, Warn Winch
72 Chev Blazer CST, 350, TH350, 4WD, factory A/C, tilt, radio delete, 77K miles, orig. paint/interior
Hoffa is offline   Reply With Quote
Old 12-29-2010, 01:46 AM   #4
Mieser3
Mieser3's Avatar
I've had great luck using an air cut off tool and cutting an "x" in the head of the rivet as deep as you can go without getting into the frame or crossmember. I then use an air hammer with a chisel bit to chisel off the head of the rivet. Once that is done I simply input a punch bit into my air hammer and punch the rivet out through the other side. Has worked perfectly for me.
Jay
1956 Chevy 210 Sedan
1970 Camaro Z-28/RS
1970 Chevelle SS 396 (numbers matching L34 car)
1971 Chevy SWB Fleetside with 1967 front clip - in progress
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=438156
Mieser3 is offline   Reply With Quote
Old 12-29-2010, 09:12 AM   #5
ChopperDr
All those methods work great, most of the time for me. Sometimes I'll find one that fights me to the end. Some that I can't get to budge with a punch will get drilled out with a step drill. That usually does the trick.
You don't have to do them all at once if you are having problems getting them out. Once one is out you can bolt it back together through the hole and keep your truck on the road if that is a concern. Just a thought.
Chopzilla
ChopperDr is offline   Reply With Quote
Old 12-29-2010, 09:31 AM   #6
72ArizonaBurb
You guys are great! I guess I will start preparing myself mentally to remove the whole thing. It has really been a big job returning the suspension to stock. Thanks for the replies!
Keith
Old 12-29-2010, 11:50 AM   #7
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Ive got a crossmember on a parts truck thats upside down in my field. Mcminnville TN. I dont own any torches, but its yours if you can get the rivits out/or bring your own torch or something.
John
1999 Toyota Tacoma 4x4
Old 12-29-2010, 10:32 PM   #8
72ArizonaBurb
Thanks for the offer on the cross member. I am going to do some checking locally and see what I can come up with. If I don't have any luck I will contact you and take a road trip. I do have a set of torches handy...
Old 12-29-2010, 10:45 PM   #9
oldblue1968chevy
Let me know something. Im on christmas break until tuesday, then back to school.
John
Old 12-30-2010, 10:00 PM   #10
1970 CST STEP
+1
1967 SWB (small window) original
1970 4x4 STEP
1970 CST SWB FLEET
1972 SWB FLEET ORIGINAL
1970 CST STEP is offline   Reply With Quote
Old 01-04-2011, 08:17 PM   #11
72ArizonaBurb
Yesterday I tackled removing the cross member. I ground the 1st off and had trouble getting it punched out. On the next ones I ground a flat spot then hit it with a punch to make a dimple. Then I drilled the center out about 1/4" into the rivet. I then took my air chisel and cut it off. This was by far the fastest and easist method to remove them. On the top 2 rivets I had to grind them off and I still don't have them punched out. Once they are out I'm ready to do it all over again on a donor truck. I'm not looking forward to that.
Old 01-04-2011, 08:30 PM   #12
Mieser3
Mieser3's Avatar
I just removed a factory trailing arm crossmember on my project if you need one. It's already even been blasted. See my build thread for pics if you're interested.
Jay
1970 Camaro Z-28/RS
Old 01-04-2011, 11:02 PM   #13
72ArizonaBurb
I have one in parts truck I have. Hopefully I will be able to remove it much easier with the cab and bed off the truck. I took the one off my Suburban with the body still on the frame. I don't want to do that again anytime soon.
Thanks for the offer!
Old 01-04-2011, 11:16 PM   #14
oldblue1968chevy
glad ya got one closer to home!
ya dont have any nice cabs up there do ya?
John
Old 01-05-2011, 12:05 AM   #15
72ArizonaBurb
I have a 72 Cheyenne Super Cab with AC but I wouldn't say it is nice. The dash is uncut but it needs rockers, cab corners and other repairs. I do have the title for it if you are going to build a project out of several trucks.
