12-28-2010, 11:55 PM | #1 |
Alterate Tach Location?
Greetings Truckers,
Would like to find an different location to mount the tach. Currently mounted to the steering column. I like it until I drive at night and get the reflection on the windshield. Was thinking of mounting to the top of the dash. Any thoughts? Thanks, MrBlue
MrBlue 72' C-10 350 TKO-600 Current Project 54' Ford F-100 Life Long Project |
12-29-2010, 05:42 PM | #2 |
its all about the +6 inches
Re: Alterate Tach Location?
I HATE the tach glare in the glass.... it's right in your direct line of sight too. I've been told I was crazy for complaining about that... even been told I was seeing things.
I installed mine in the dash to prevent this, in the center hole where the factory one would have gone. |
12-30-2010, 12:09 AM | #3 |
I vote center hole of cluster also. I actually disassembled my SunPro tach and mounted it from behind the original cluster lens for a more factory look. Turned out pretty good.
You can see it if you check thru my old threads.
68 C10 Shortbed Fleetside 06 Chevy Ext Cab Fleetside 03 Grand Prix GTP My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999 |
12-30-2010, 01:08 AM | #4 |
What about on the windshield pillar? Does anyone have it mounted there and how is the visibility?
Posted via Mobile Device |
12-31-2010, 02:50 PM | #5 |
Knee knocker stlye
12-31-2010, 03:17 PM | #6 |
Mine was mounted on the column when I bought my truck, but I moved down to the knee knocker position now..lol,,,although it is still attached at the column.
I can't see it really well without looking though, but I dont need a darn tach in a cruiser anyways lol |
12-31-2010, 07:42 PM | #7 |
RAT1968 '68 Cab/'71 Parts
Here's mine:
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
12-31-2010, 07:50 PM | #8 |
Getcha Pull
What is that second one? Sun? I like that Short-Sweep look.
'81 K10 454/SM465 '86 S10 Blazer '95 H-D Softail '96 Integra |
01-01-2011, 02:28 PM | #9 |
The second tach is stock chevelle. I think Year One still carries them for around $200
01-02-2011, 09:45 PM | #10 |
Getcha Pull
Oh, ok. Thank you! My first thought was maybe a GM, but I thought the numbers looked closer together.
01-02-2011, 10:16 PM | #11 |
Old member
I would have to agree with the tach in the dash for the best place. My next choice would be on the right windshield pillar. Next would be on top of dash at a angle to the driver.
19seventeeCustom, I would never mount mine that low myself. My reasoning is simple. If your ever in a bad wreck heaven forbid and you go into the dash that thing is going to cut your leg off. Just my thoughts on having anything mounted low in the drivers side of any vehicle.
01-03-2011, 12:22 AM | #12 |
Sierra Grande Club
Here's one
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
01-03-2011, 10:20 PM | #13 |
I have a sport comp tach mounted on top of the dash. Never had any problems of glare.
1970 Chevrolet C-10 w/355sbc 2010 Silverado Daily Driver 1971 Mercedes 280sl project car |
01-04-2011, 08:22 PM | #14 |
Bad70, do you have any pictures of how the tach is mounted to the top of the dash?
Anyone, is a pillar mounting panel made specifically for our trucks? |
01-15-2011, 11:39 PM | #15 |
Sorry it took so long to post, Spring Classes just started.
01-16-2011, 12:12 AM | #16 |
Old Skool Club
When GM mounted those tachs in Malibus like that pic had, all we thought at the time was, "it's got a tach". Mfr's didn't have tachs as standard equipment. If you had a Grand Prix (Pontiac), a Star Fire (Olds) or a Wildcat (Buick), it would be mounted on the console....if it had a stick. If it was an automatic, you got a vacuum guage. Regardless, until Pontiac put the tach in a pod on the hood....in front of the driver....finding the tach was difficult if you were serious about using one. In those cases, they got mounted where you could see them, and where you could show it off....on top of the dash and offset just a touch.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
