12-29-2010, 12:02 AM | #1 |
Washerless Bed to Frame Bolt Kit? Do They Exist? Please help!
Hello all, im going to be doing a mahogany bed on my 70 chev stepside, im going to be doing all the carpentry work obviously since you cant buy a mahogany bed. I want to find a wood bed bolt kit that does not use the offset washers to secure the bed to the frame. I dont want to recess for any washers in the bed. Anyone know any websites where i can purchase a bolt kit like this?
thanks in advance! -DaDark |
12-29-2010, 01:44 AM | #2 |
Re: Washerless Bed to Frame Bolt Kit? Do They Exist? Please help!
you need the offset washers to be able to tighten the bolts or else it would just keep spinning in circles. some people just reinforce the cross strips and mount the bolts under the boards (example( http://www.mar-k.com/Catalog/catalog.aspx) I just made my own boards from scratch for my bed and think the offset holes were alot easier than i originally thought but make sure you drill the offset hole before the bolt hole, it is very difficult using a forstner bit with a hole already in the center (ask me how i know...haha)
12-29-2010, 01:52 AM | #3 |
i want to avoid having any visible frame to bed mounting hardware from the top.
12-29-2010, 01:58 AM | #4 |
Like This ???
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 |
12-29-2010, 01:59 AM | #5 |
uh, yes! can you give me an idea of how to do this?
12-29-2010, 02:14 AM | #6 |
12-29-2010, 02:48 AM | #7 |
wow, awesome site, props!
12-29-2010, 12:12 PM | #8 |
Florida Edition
WOODBEDANDPARTS.COM has bed kits for domestic and EXOTIC hardwoods.
Ordered a Cypress one yesterday.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
12-29-2010, 05:01 PM | #9 |
I welded studs into the cross sills.
No need for bolts when you have studs welded in
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
