12-29-2010, 03:03 PM | #1 | |
zero rate kits
so first off, do they make one of these for the rear of my '67?! i have been told that the front springs are 2 1/2 and the rear are 2 1/4, and ORD only makes then for 2 1/2" and 3", that is if im on the right page.
second, can i install one of these just to give lift, not to offset the axles any? what would be the pros and cons to this system (if possible), and what would i get out of moving the axle an inch??
1967 K-10 4x4 with a 3" lift and 35" BFG mud terrains Quote:
want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there |
12-29-2010, 08:15 PM | #2 |
Currently Blazerless
Re: zero rate kits
I would think the 2.5" should be fine with your 2.25" springs...That only leaves about 1/8" overhang on each side..as long as your u-bolts clear them. And yes you can pin them to the spring in the center position..the offset would be used if your tires were not centered in your wheel openings such as when using a shackle flip.
I really don't know of any cons on using these on your rear springs as long as your not combining them with another lift block...really a safe simple way to gain an extra inch if that's what your looking for.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
12-29-2010, 08:18 PM | #3 |
Re: zero rate kits
Also DIY4X makes these, like ORD he turns out a real quality product.
http://diy4x.com/cart/index.php?rout...product_id=128
12-30-2010, 11:16 AM | #4 |
Re: zero rate kits
If your springs are sagging then yes you could use this to level your truck. The only reason to move the axle is to center the wheel in the fender. I just helped a friend install a set.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
