Old 12-29-2010, 04:27 PM   #1
planewhisperer
U.S. Army Green Beret Sniper
planewhisperer's Avatar
72 C10 charging system
Hello everyone, My son has a 72 C10 and having alittle problem with charging system. System has external voltage regulator. With truck running I only have 12.34 volts approx at the battery terminals. Does anyone know what the voltage should be from the alternator blue and white connector on the alternator. Does anyone know how the direction of current ie battery, alternator and external voltage regulator.
"YOU CAN RUN AND YOU CAN HIDE, BUT YOU WILL JUST DIE TIRED"
planewhisperer is offline   Reply With Quote
Old 12-29-2010, 05:23 PM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: 72 C10 charging system
Voltage at battery with the engine running should be 13.5-14.5 volts, I think.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
