Bedside Tool Box Help
I have no key and lock is stuck(key blank wont go into the lock). Any Ideas of how to get access to tool box?
TIA Thanks ![]() |
![]() Join Date: Dec 2003
Re: Bedside Tool Box Help
the box behind it might be able to be taken out from the back.. maybe drill out the screws holding it to the bed... just climb under there and look around and see if you see a point of access...
https://www.ebay.com/itm/295742064443 |
![]() Join Date: Mar 2009
I have the same problem. I was gonna drill it but instead I called a lock smith and was quoted 60 for re-keying it. I hope when he opens it there will be some goodies inside.
#4 | |
Always on the hunt...
![]() Join Date: Sep 2006
What if I have the key, but the handle has broken off? All that's there is a rod at the top going across horizontally, passing through two metal tabs in the center. I know this is an old thread, but it's the most relevant that came up in my search results
You need to reach out to boardmember LockDoc. Leon knows all.
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
Moderator
![]() Join Date: Jun 2008
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
#8 | |
The Older Generation
The lock is completely seperate from the handle and prevents the lock bolt from retracting. This is a positive locking mechanism which means if you can't get the lock cylinder to turn you are probably not going to get it open without damaging something... I have been working on GM locks since 1977 and the sidebar lock cylinder (used unchanged since 1935) is the hardest lock to crack of almost any automotive lock. Nearly impossible to impression, nearly impossible to pick. If the locksmith has a set of tryout keys he may be able to go through those and get it open but there are 150 keys in the tryout set and it takes a while to try all of them. That didn't work for me... On a side note, does the ignition key for your truck work in your door locks? I would insert the nozzle from a can of penetrating oil (not WD-40) into the key hole and spray the crap out of the inside of the lock cylinder then try the key again, wiggling it as you insert it. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 04-10-2023 at 11:33 PM. |
My square ignition key also operates the door locks, and the circular key fits the tool box. The lock to that box turns and seems to function normally, but the handle has broken off.
#10 | |
I will post a solution for you in the morning if it isn't still raining cats & dogs then. I have to go out and check the door on my '70. LockDoc
I just went out to my truck to fiddle with it some more..... YATZEE!!!
I was hoping to find treasures inside
#13 |
My keys don't work either (ignition key fits though), but behind the door is a second gas tank, so not sure which actually belongs there.
#14 |
![]() Join Date: Oct 2009
Yankin the tool box and stuffing an additional fuel tank behind it isn't undeard of. My PO actually did that and, unfortunately, welded sheet metal over the opening... Ugh. Anyhoo. Dealer installed saddle tanks went exactly where the box would go, if someone installed saddle tanks. The tool box portion from a member on the board on the parts section, if you want to re-install it. They come up every once in awhile. But, if you'd prefer the extra gas, don't toucha nothing. And welcome to the board Tim.
#15 | |
Here is what belongs there. This one happens to be for sale..... http://67-72chevytrucks.com/vboard/s...d.php?t=662542 LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 04-10-2023 at 11:42 PM. |
