![]() Join Date: Oct 2005
vent window gasket replacement questions
who has done the regasket installation on their vent windows and used the rivet tool supplied to set the rivets. If anybody has done this could you help a man out by giving some advice on how to get this done. I sure would appreciate it.
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod. ![]() |
Moderator
![]() Join Date: May 2007
Re: vent window gasket replacement questions
Use pop rivets, makes life a LOT easier. I have done 2 sets. Do not remove the "pivot" rivet that the window swings on. Instead, remove the bracket that holds the pivot rivet, and use 2 pop rivets to secure it back after replacing the rubber triangle piece.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
I did mine about a month ago and its really not all that bad. You just gotta jump in there and do it. Take some photos or write things down how they go as your disassemble your old ones. Drill out the old rivets, put the new ones in- mayby not quite that easy but its not super hard to do. The second door goes twice as fast since you know what your doing...
Moderator
Also, look in the FAQ index, there are a lot of helpful hints on this subject.
Thanks guys. I had started out with the search button but nothing came up. Then used google and it led me back here and one of our members had written a how to on it and shared the secret I was looking for on how to use the rivet setting tool. I actually did the passenger side today before I asked the question and was just baffled on how to use this tool with only two hands. But seeing how he did it will make a ton easier. flat punch in vise and rivet tool in hand. I will try this tommorow on drivers side vent when I find another one at the pull a part. I was looking at mine and noticed the track is bent so I am not going to spend the time messing with a bent up frame. Thanks again everybody. And all the paint is supposed to be finished tomorrow and will be putting it all back together on Friday. Wish me luck.
spray the weatherstrip with pledge its way easier to get the rubber back in place, youll thank me later....
it usual better and faster if u figure it out yourself!!!! ![]() |
Well, I know when I did mine, even with my dad's help, I knew we had to stick out our tongues just the right way, we argued, we said some swear words, argued some more, tried sticking tongues out a different way, argued, walked away and cooled down, came back to it, held tongue out different than before, wrestled with it, held in frustration at dad cuz "I" wasn't doing it right, finally held tongue just right, and finished.
Ok.....proof read...........yup that about sums it up. ![]()
