12-29-2010, 09:30 PM | #1 |
Heater question
I'm flushing out my my 65 radiator and don't know where the heater control is to flush out the heater core as well.
Anybody know where the heater temperature control is or does it have one? All I see is a pull knob that says air and it turns three clicks, I'm assuming that's the fan control and vent? The heater core was disconnected and the lines looped back to the motor by the PO because the core was leaking. I hooked the lines back up and hope to use some bars leak or something to fix the core... does that ever work? Thanks guys! |
12-29-2010, 11:36 PM | #2 |
Re: Heater question
If the heater core is original , I doubt anything is going to stop the leak on a 45 yrs. old heater core . They aren't that expensive nor difficult to change out . LMC has them in the $ 70 - $ 80 range ( depending on which type your truck has ) . I bought mine many years ago through Autozone . They have them listed on their website for $ 31.99 !
" The lesson is in the struggle , not in the victory " Last edited by oldblu65; 12-29-2010 at 11:38 PM. Reason: update |
12-30-2010, 12:42 AM | #3 | |
Re: Heater question
I just called Autozone, 33 bucks.. can't beat it It's amazing the stuff I've been able to get for the truck at autozone and kragens or whoever they are now thanks again! |
12-30-2010, 08:37 AM | #4 |
and a few others
Re: Heater question
turn for fan and pull for heat.
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
01-01-2011, 02:01 PM | #5 |
Re: Heater question
StevieC, Did you buy the core from AZ? I only see 1 on the website. Is it the smaller of the 2 sizes of core? I have the delux heater with 3 levers on the dash.
http://www.autozone.com/autozone/par...mString=search
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate. Maintenance, repairs and upgrades on his dime now. http://zacks64longfleet.shutterfly.com/ Higher res. photos in my gallery. |
01-01-2011, 02:02 PM | #6 |
Re: Heater question
63 & 64 Bowties, is the turn for fan and pull for heat heater the standard version?
01-01-2011, 04:34 PM | #7 |
and a few others
Re: Heater question
Pull for heat. The further you pull the further the valve opens.
01-01-2011, 07:32 PM | #8 |
Re: Heater question
Where can a replacement cable be purchased? Mine pulls very hard but it works. Also what holds the lever open for the defrost/heat selector?
01-02-2011, 11:24 AM | #9 |
Re: Heater question
LMC sells the cables, if you pull yours out and soak it down with PB blaster or wd 40 leave it hang in your garage for a couple of days it will loosen up, and when installing don`t tighten down on the clamps too tight.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
